Old 2nd August 2014, 02:33 PM
theschmallfella theschmallfella is offline
Only 2 aerials, are you sure? There are 4 in a row along the top edge at the back.
But in addition to that there's a little (aerial splitter?) box between the Tuner and aerials and I never did work out what that does, there are lots of versions depending what you have installed and they're usually hidden behind the rear seat back on the nearside.
See also my previous post:
Oh hang on, you're right, I was going from memory there, I just popped out to the garage for another look. Looks like the tv part of this system is a mine field, aftermarket seems the way to go. Sorry for being a bit dumb but what does the t-era part that you linked to do?
Old 2nd August 2014, 02:37 PM
Takes standard CVBS/Audio input and feeds via a lead to the back of the RNS-D.
Seems to be automatically recognised so if you select TV on the RNS you see/hear whatever video/audio input is going into the box.
Also has a button to allow video-in-motion, though I've never tried that (didn't bother wiring it in).
Read the description on the product page, it explains what it does.
Old 2nd August 2014, 03:01 PM
Ah yes, I think I get it but correct me if I'm wrong... if I get an aftermarket digital tuner, I can connect it to RNS-D head unit via the ter-a unit? Am I on the right track? I'm still very new to all this so I just need to get my head around what I need and don't need.
Old 2nd August 2014, 03:04 PM
Yes, though I think there are similar devices from other suppliers, that one just did what I want.
Old 2nd August 2014, 03:35 PM
Ok, well that's something for me to go on then, I may as well forget about the analogue tuner then and go aftermarket with the tv side of things. Thanks for all your help on this, it's very much appreciated.
Old 4th August 2014, 10:40 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Why not use the AV1 or AV2 input and attached a digital tuner to that input?
[center]
06 3.0TDI Quattro:
Options:
