Old 30th August 2014, 06:36 PM
d.f. d.f. is offline
Has anyone experience with Revo remaps?
http://www.revotechnik.com
Old 30th August 2014, 07:18 PM
Just type in Bristol, trust me, you won't be disappointed
http://www.viezu.com/index.php?optio...map&Itemid=664
Old 31st August 2014, 02:03 AM
sarg sarg is offline
you should check out MRC Tuning in Banbury, I don't have any experience myself but I am told they are simply the best for VAG
2019 BMW M5 (my daily driver)
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 31st August 2014, 08:54 AM
All the companies you've been recommended are good They're usually about the same price too, so it's pretty much, pick one you like the sound of.
The only extra that Shark really have is the STS system (unless the others have similar that I've not seen), where you can upload the normal, fast or an economy map as you see fit.
Old 31st August 2014, 09:09 AM
That is interesting. And how do you upload them?? Like via laptop or there is a box somewhere with all three maps and you just use a switch or something and box does the uploading??
I assume this can't be done while driving.
Old 31st August 2014, 09:57 PM
Pretty sure you have to decide before you start the engine. It also has a 'no map' option to stop it being started. And you can remove the unit.
Old 31st August 2014, 11:07 PM
I dropped them a line today.
Old 31st August 2014, 11:13 PM
Thanks. Will def look into them. They come highly recommended also.
