D2 PF help reqd
anyone?
Don't remember seeing one like that on left side but I do have one like that or very similar on the right side that plugs in in double temperature switch on the radiator on 1998 S8. I will have a look later.
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 6th November 2014 at 11:50 AM. |
Thanks that would make sense - and it depends on your L&R - if I am standing in front of the car it is to my right :-) |
Sorry forgot to check on my car.
I can see in the picture that it is in the left side of car( as you sit in) where the ABS pump is. I have now checked on my car 1998 S8 RHD and I cannot see that plug on my car, only one that looks the same is on the other side where the airbox is and that goes to double temperature switch in the radiator. Maybe I just cannot see or it could be the difference between LHD and RHD or between A8 and S8. Or maybe if the front end have been off your car the cable is now routed to the wrong place. I will check Etka in a short while to see if there is different part number for radiator between LHD and RHD or A8 and S8 4.2's.
Looks like there are 2 radiator possibilities for PF V8's, no difference between RHD or LHD or A8/S8, only depend on chassis number but I do not know if temperature switch is on the same side on both or not.
had a look round the radiator and cannot see any plug - think I need to get it on ramps for a proper look
Does look like the radiator plug - on my FL A8 it was on the left as you look into the engine bay - very awkward to get to but doable!!
Andy. Current cars: BMW i4 M-Sport Peugeot 207 (the sons) Triumph Daytona 675 (2017 reg) =========================== Gone but not forgotten Ford Focus ST-2 Mk3 (the wifes) (stolen Oct 2023) 1972 T2 Bay Window Camper (Slow) Audi TT Mk1 225 - now with coil-overs and a 7inch touchscreen infotainment centre 2003 A8 Sport 4.2 (with ACC & LPG) (Feed up with all the issues so passed it on to a forum member) 2000 A8 FL QS 4.2 (with RNS-E - Nice) (Engine poorly so sold on to be brought back by someone who has the time) |
Have the same on my 1996 4.2/ Goes to nothing. Noticed it when i changed the cambelt
Plug a scanner into it and read what the coolant temperature is. If its giving an incorrect reading this could make fans come on all the time.
May not help but it happens with modern vw's/skodas, if the outside air temperature sensor is not working or have the wires cut/broken OR by unplugging it from the sensor it has corrosion inside THIS will make the fans stay on. Its located at the front bumper area "EDIT" ignore previous post though it was the right hand side |
