Diagram of pass side front end
Hello
Doing up a damaged 07 4.2tdi ,its been hit on the passenger side front end were the AIR Compressor is located , i need a diagram of the compressor location so i can reinstall everything correctly! Parts needed so far Wing Headlight Compressor cage Wheel arch liner Intercooler bracket (only thing i cant get) Looking at rebuilding tommorow morning(Sat) so if anyone could sort me out that would be great. Tested the air suspension and all looks ok as does the rest of the car ,it was only very lightly damaged so no airbags deployed and no warning lights on dash , only other problem is MMI screen , ive allready ordered the brass cog kit so will get that done asap. VIC check on Tuesday at 11am so wish me luck it all goes well!!!!!! Thanks PWACKA8 |
