Old 22nd June 2018, 10:44 PM
Chip2786 Chip2786 is offline
Default Just Fitted a Fire TV On MMI 2G
I had a spare input on my digital tuner so I thought I’d stick at Fire TV in it. It works amazingly and now I have built in Netflix, Kodi, Apple Music, iPlayer etc. On all 3 TV’s Proper chuffed with it.
Here’s what I needed;
AV in cable
https://rover.ebay.com/rover/0/0/0?m...2F381575113139
4G Router and SIM card
Huawei E5577 Black 4G Low-cost Travel Wi-Fi, Super-Fast Portable Mobile Wi-Fi Hotspot – Long-lasting Battery
https://www.amazon.co.uk/dp/B011YM0O..._vTxlBbDCR7CJA
HDMI to Composite adapter (I had one of these in stock but this should do)
https://www.amazon.co.uk/dp/B01N5KNF..._EXxlBb4MGJPCF
And 2 of these 12v to 5v converters
https://www.amazon.co.uk/dp/B00G890M..._L2xlBbMZYJ8R9
ID:	19598   Click image for larger version
ID:	19599   Click image for larger version
Jobs done so far;
Fitted an RS Steering Wheel, Fitted 15mm wheel spacers, Lowered 10mm with VCDS, Reinstalled factory DVB, Unlocked VIM, Updated MMI to 5570, Fixed Factory Bluetooth Phone, Fitted heated fan-spray washers, Installed Bluetooth DAC For Audio, Added projection Puddle lights, Wind Deflectors, Fitted Apple TV to all 3 Screens, installed car WiFi, Fitted Custom vortex Exhaust
Old 22nd June 2018, 10:45 PM
No idea why 2 of the pictures are upside down
Jobs done so far;
Old 23rd June 2018, 12:37 AM
H-M3 H-M3 is offline
That’s cool any chance of getting some wiring pics? I have 3 of those cables not sure what colour pins go where on the dtv
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 23rd June 2018, 12:31 PM
Sure, next time I have the DTV unit out I’ll get some pics.
If you have a continuity tester it’s easy enough to figure out which pin does what, then you just use the attached pin outs on the DTV plug
Jobs done so far;
Old 24th June 2018, 09:35 PM
Hello Chip, I like what you have done.
Do you have any audio whine/hum whistle (ground loop feedback).
I do and I'm using a bluetooth receiver on AV1 and a MOTOVIEW airplay/chromecast on AV2 and was wondering if your power supply would be better than my USB cigar adapter.
Old 25th June 2018, 03:51 AM
There is a slight high pitched hum when no audio is playing but it’s not Audiable when something is
Doesn’t the cig socket stay powered all the time?
If you are getting a ground loop you could try this?
https://rover.ebay.com/rover/0/0/0?m...2F250489744414
Jobs done so far;
Old 19th July 2018, 12:05 AM
[quote=Chip2786;143166]Sure, next time I have the DTV unit out I’ll get some pics.
How is the apple Airplay going buds? Any chance of those pics? You couldn’t tell me what colour is what on those aux cables? Cheers
