Old 8th June 2019, 08:07 PM
Chip2786 Chip2786 is offline
Default DVB/ TV amplifier question
Does anyone know the difference between the 4E0035225AL and the 4E0035225AK Div amp? I’ve seen both on EBay but the AL version is £135 and the AK is on £60
Jobs done so far;
Fitted an RS Steering Wheel, Fitted 15mm wheel spacers, Lowered 10mm with VCDS, Reinstalled factory DVB, Unlocked VIM, Updated MMI to 5570, Fixed Factory Bluetooth Phone, Fitted heated fan-spray washers, Installed Bluetooth DAC For Audio, Added projection Puddle lights, Wind Deflectors, Fitted Apple TV to all 3 Screens, installed car WiFi, Fitted Custom vortex Exhaust
Old 9th June 2019, 12:44 PM
There is some info here...
http://forum.a8parts.co.uk/showthrea...35225AK&page=2
You could also look on here...detail and cross reference all the PR codes on a VAG decoder website...
https://audi.7zap.com/en/rdw/audi+a8.../a8q/2006-291/
I think one is for the rear window without the heated element lines, instead it has the blue/purple metallic vapour coating you used to see on French car windscreens in the early 00's.
