Old 24th March 2015, 03:26 PM
I don't have the six connection wired up on mine but yes that's my understanding of it, it basically repeats what input you have selected to the output so you could in theory split the output and send to headrests
Old 26th July 2015, 07:35 PM
I can confirm that the Aux Output gives a video/audio signal for the RSE(Rear Seat Entertainment). The output is whatever you have selected on the MMI.
I do not have RSE so I borrowed Guy's car and used a long RCA cable to send my Output to his Aux 1 input. Whatever I selected on my MMI was relayed to his MMI.
To save any misconception here are the pinouts tidied up:-
Aux Input 1
PIN 09 – Audio Shield left/right
PIN 10 – Audio signal left white
PIN 11 – Audio signal right red
PIN 12 – Video signal yellow
PIN 13 - Video Shield
Aux Input 2
PIN 15 – Audio Shield left/right
PIN 16 – Audio signal left white
PIN 17 – Audio signal right red
PIN 18 – Video signal yellow
PIN 19 – Video Shield
Video output (only for Hybrid-Tuner)
PIN 4 – Video Shield
PIN 5 – Video signal yellow
PIN 6 – Audio Shield left/right
PIN 7 – Audio left white
PIN 8 – Audio right red
Old 2nd August 2019, 09:33 PM
Simons's Avatar
Simons Simons is offline
Hi Guys,
Tonight I tried to fit my iphone streaming gizmo only to find that the Aux in is not accepting a video signal.
The audio is ok so I need to investigate the problem, but for the life of me I can't find wiring diagrams for a aux input in elsawin or ebahn.
Am i being stupid?
If someone has the diagram and could post I would be very greatful
Wouldn't mind a link to people selling the harness either, cheers
I have the opposite problem, the video works fine but the sound doesn't....I ear sound, but totally distortional.
I connect the kufatec cable in AV1 and AV2 pin out but the same result... perfect video and sound distortion.
I checked the cable with a multimeter and looks good. Also with another mirror link, and the same problem always.
What could be the problem?? My car has B&O
A8L 4.2tdi Night Blue Pearl//Torrone Beige & Jive with everything except rear entertainment and fridge
Old 8th August 2019, 09:03 PM
Chip2786 Chip2786 is offline
When I first fitted the Apple TV in my car the audio buzzed like a mofo, I bought a cheap ground loop isolator from eBay and now it’s perfect, could be worth a go
Here’s a linky
https://rover.ebay.com/rover/0/0/0?m...2F250489744414
Jobs done so far;
Fitted an RS Steering Wheel, Fitted 15mm wheel spacers, Lowered 10mm with VCDS, Reinstalled factory DVB, Unlocked VIM, Updated MMI to 5570, Fixed Factory Bluetooth Phone, Fitted heated fan-spray washers, Installed Bluetooth DAC For Audio, Added projection Puddle lights, Wind Deflectors, Fitted Apple TV to all 3 Screens, installed car WiFi, Fitted Custom vortex Exhaust
Old 11th August 2019, 04:46 PM
Simons's Avatar
Ok thanks! I'll buy them. I found a cheap one with "gold" plated connectors and CE marking. I'll post the final result 😉
Thanks again!🍻
