Old 27th June 2009, 02:55 PM
A8 Owner A8 Owner is offline
Default red open door red light
MRS A8 Owner
Right driver side is stopping on, cant find the switch (where is it). Is there anything else i should be looking for. Is the fuse for it just for door lights, or does it do other things aswell, and if so what?.
Steves away, so cant ask him to do it Not scared to learn & have a go.
To Mod can u change title to the right name thanks
Old 27th June 2009, 07:25 PM
The door open sensor is in the door lock itself if I remember rightly, have a little look and see if something is stuck in there.
Old 28th June 2009, 11:44 PM
Thanks for info ive sprayed wd40 around that area as u cant see much and kept opening and closing door to work the wd40 in.
Amazed how much heat comes from it, when it doesnt go out. It stopping on for a afternoon and night. That gives u flat battery. Guess how i found out
Looks like light pulls out, So if i got flat battery in morning, ile pull it out and take bulb out, till Steve gets back.
