Old 13th August 2015, 10:48 AM
Default FL LED tail lights
Just a quick one, can you easily remove pcb with all the leds on the latests FL tail lights??
I'm working on swing indicators like on the new A8s and Q7s for example, but I do have doubts after realizing that indicator strip is really short on our 8's so it ay not look as cool as on newer models.
Old 13th August 2015, 11:14 AM
When I fitted mine, it looked like it was a sealed unit apart from aperture for the fog and reversing bulbs. It also looks like Audi moved to LED strips around 2008...
Easiest thing to do is whip off the 2x 10mm nuts on the outer lamp and swing it out. It would only take 5 mins if you don't drop the nuts into the darkest depths of the bodyshell.
Old 13th August 2015, 11:48 AM
I too thought the same thing Marcin but the units sealed, doesn't mean it's impossible but certainly not easy
Old 13th August 2015, 06:09 PM
Lee S Lee S is offline
Saw these on a brand new RS6 Avant the other day.... WELL Cool !!!
Lee
2017 Nissan Leaf Tekna
Old 13th August 2015, 10:33 PM
Turbo Tony's Avatar
It's amazing how tastes change, right?
Seeing the Ford Mustang in USA, on which three lights flash in turn while indicating, so many people said it was a cheap and nasty bit of automotive theatre. Had we, at the time, fitted something similar to our own cars, we would have been called all manner of names and people would have made KITT jokes at our cars.
Fast forward a few years, and Audi does the same thing with LEDs and we're all wowing at the effect!
(for the record, I'd like to point out that I'm not immune to the charms of the swinging indicator and would like one myself)
Storytellers Villa Orlando
2008 Audi S8
Old 13th August 2015, 10:43 PM
Perfect solution for you
http://www.dealers.motortrak.com/det...479&vidindex=0
Old 13th August 2015, 10:52 PM
Turbo Tony's Avatar
*thud*
2008 Audi S8
Old 14th August 2015, 01:04 AM
In 1958 when I was first posted to Germany we had big Magirus Deutsche trucks and they had swinging indicators, but they were semaphore arms with a light on the end. They operated fully electrically, whilst our British manufactured wagons had an arm that was pulled out with a mechanical linkage from a lever in the cab.
Then we had to remove these semaphore trafficators and fit flashing indicators.
