Old 21st October 2015, 07:31 AM
Default Rack
Will a FL rack fit a PF 8?
Old 21st October 2015, 08:28 AM
The part numbers in Etka are very similar
For a '96 it lists 4d2422052b (with an x for an exchange unit on the end) and lists it as 'FA ZF'
For a 2002 it lists 4d2422052f (with x) and lists as 'ZF'
Given the number is the same it suggests only a revision, but Etka doesn't mark the f revision of superseding the b part number, which it just says has been dropped.
It definitely relates to PF/FL as the old number changes in '99 based on VIN.
I suspect the forum sponsors are your best port of call for a physical comparison?
Old 21st October 2015, 08:29 AM
A8parts will know the answer I'm sure.
Servotronic (1N3) (or not) (1N1) were the two big D2 differentiators to also consider.....
