Old 10th December 2015, 04:20 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Default Brake light warning came on after brief spirited driving
Hi all.
Did a U-turn very quickly and the traction control light flashed, then under acceleration the brake warning light flashed at me. Then went off. Hasn't come back on. I got home and thought I'd check the level of the fluid. The cap doesn't have a dipstick (nothing is simple). I wondered if VCDS would shed any light on the level or any fault codes.
In addition, some history:
Recently the N/S/R exterior keyless door lock button stopped working. No biggy. Contact cleaner didn't help. I mention this as there is a central convenience fault logged.
When I bought the car a year ago I scanned it on the test drive and the battery regulation fault that is present now, was then. So again, no biggy. The car starts fine.
When in the brake module I scanned for faults, there weren't any. I ran an output test (I know now I should t have). DIS went a bit nuts and a fault code 14 I think was logged. I read the procedure for clearing this on Rosstech's site, and tried to clear this, without luck.
So, to the scan:
Thursday,10,December,2015,16:24:52:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 4L0
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 18 19 1E 28 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 67 72 76 77
VIN: WAUZZZ4E59N003044 Mileage: 189500km/117749miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Not registered 0001
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Cannot be reached 1100
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Part No SW: 4E0 910 402 G HW: 4E0 907 401 D
Component: 3.0L V6TDI G000AG 0030
Revision: --H05--- Serial number: AUX3Z0H5352725
Coding: 0011973
Shop #: WSC 02313 785 00200
VCID: 2045FE59F3D8C29
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 Q HW: 09L 927 156 A
Component: AG6 09L 3,0 TDI RdW 0020
Revision: --H01--- Serial number: 4462379
Coding: 0000001
VCID: 31630B1DA8327B1
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 J HW: 4E0 614 517 CP
Component: ESP 5.7 allrad H50 0540
Coding: 0008357
Shop #: WSC 02313 000 00000
VCID: 2A511C7185E4089
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 A
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0H5352725
Coding: 0412672
VCID: D8B516B96B08CA9
Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3670112
VCID: 244DF249E7C0DE9
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 P HW: 4E0 035 729
Component: Interfacebox H43 5140
Revision: 00000000 Serial number: 343FM087606601
Coding: 0000002
VCID: 2F670D65BE066D1
Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000151223
Coding: 0018449
VCID: 1C3DCAA9DFB0E69
1 Fault Found:
00065 - Left Rear Footwell Heater (Z42)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 6
Reset counter: 18
Mileage: 175130 km
Time Indication: 0
Date: 2015.05.27
Time: 13:00:41
Freeze Frame:
Voltage: 11.60 V
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0143121
VCID: 387536394B48AA9
Subsystem 1 - Part No: 4E2 910 113 C
Component: Wischer WWS D3 H60 0440
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046002 Serial number: AUZ5ZBH8466025
Shop #: WSC 00000 000 00000
VCID: 1A31CCB1D584989
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276W7200545
Coding: 0000001
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 E HW: 4E0 959 655 K
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CU000G2R4
Coding: 0431707
VCID: 2855E6799BE83A9
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 C
Component: J0527 0410
Revision: 00H05000 Serial number: 90055081590136
Coding: 0112141
VCID: 2649E84191FC2C9
Component: E0221 H02 0030
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 J HW: 4E0 920 951 J
Component: KOMBIINSTR. VDO H84 0620
Revision: D03 Serial number: AUDID3H5100027
Coding: 0000423
Shop #: WSC 10158 000 1048576
VCID: 2C5D1A698F10169
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 G
Component: Heizgeraet H08 0140
Revision: 0000000C Serial number: 00000009013887
Coding: 0000001
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B0861500DF
Coding: F5F99F7F507A0E00
VCID: 2D5B176DB40A1F1
2 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 243
Mileage: 189458 km
Time Indication: 0
Date: 2015.12.10
Time: 11:51:30
02077 - Media Player Position 2 (R119)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 167
Mileage: 173884 km
Time Indication: 0
Date: 2015.04.19
Time: 18:14:00
Address 1E: Media Player 2
Cannot be reached
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 C
Component: KLIMA-STG. FOND 017 0230
Revision: 00000020 Serial number: 00000000073194
Coding: 0000000
VCID: E1C33B5D38520B1
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 K HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 4590
Coding: 0015510
VCID: 2B5F19758A1E111
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 3670122
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H52 1060
Revision: 00000000 Serial number: 364F%087797346
Shop #: WSC 00720 210 91789
VCID: 3B7F29357A7E811
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000815200094
Coding: 0035968
VCID: 1D3BC7ADC4AAEF1
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 F
Component: Türsteuer.FS BRM005 0180
Coding: 0028462
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H10 0030
Revision: 00300010 Serial number: W040806190053
Coding: 0004317
Part No: 4E0 907 719
Component: Neigungssensor H05 0020
1 Fault Found:
00892 - Switch for Trunk Closing Cylinder (F248)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 26
Mileage: 189400 km
Time Indication: 0
Date: 2015.12.09
Time: 14:35:39
Address 47: Sound System Labels: Redir Fail!
Part No SW: 4E0 910 224 B HW: 4E0 035 223 H
Component: Amp.-Basis H41 0150
Revision: 00000000 Serial number: 00000087525075
Coding: 0000013
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 D
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000026332
Coding: 0010101
VCID: 1E39C0A1C9ACF49
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 F
Component: Türsteuer.BF BRM005 0180
Coding: 0028462
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000221
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Coding: 0000006
VCID: 3F875D256E669D1
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396F2087597823
Coding: 0000001
VCID: 2E591061B90C649
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000011259
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2806200063
Coding: 344530393135313035412056413032383036323030303633
2 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 3
Mileage: 175584 km
Time Indication: 0
Date: 2015.06.10
Time: 13:13:05
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 1048575 km
Time Indication: 0
Date: 2015.06.10
Time: 13:18:34
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0028462
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H46 0630
Revision: 00000000 Serial number: 00000806170058
Shop #: WSC 12336 024 394758
VCID: 36693801415C5C9
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0028462
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720814902398
Coding: 0201008
VCID: 234FF155E2CED91
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 C HW: 4F1 862 335
Component: BTA H11 0960
Revision: 00H11000 Serial number: 00000007580693
Coding: 0060001
End ---------------------------------------------------------------------
Can anyone shed any light on what may be the cause of the brake light, is there a way to manually check the fluid level?
Could a dicky battery be the cause of random faults?
Thanks for reading. John
2007 Mini Cooper S R56
Old 10th December 2015, 07:51 PM
Can you see the fluid level in the resvoir, the accelerating away quickly and it flashing on does sound a bit like fluid level thing .
With regards to the battery regulation , go into the battery regulation module and go into data blocks look for s.o.c .... state of charge ,with engine running see what the percentage is and post up .
Old 11th December 2015, 10:48 AM
Johnmed's Avatar
Thanks for that Lee.
Ok. Fluid was difficult to see, but topped up with Dot 4.
The battery SOC is 60.0% could that be because of the weather and because I was running VCDS last night?
Old 11th December 2015, 11:49 AM
If topping the fluid up fixes it bear in mind your brake pads could be getting low or could just be low on fluid for some other reason .
Take car for a good run 30 mins or so and see if state of charge gets any better
I had similar on mine , my auxillary heater kept knocking its self off in a morning , my car has had a new Bosch battery over orginal spec , but in the drop down list bosch batterys was not in there , i was getting the quiecent current stage 1 2 3 codes , so battery regulation stopped the aux heater from working .my S O C was 60 % or around that
See on the coding at the end the 105A im assuming that means 105 amp hour because thats what was on the orginal battery , so i changed that to 115A ....press do it /ok .
It changes the very long code slightly by 1 or 2 figures
The state of charge then went up to 90 % after a 10 min drive around it went up to 100 % , my aux heater as worked a treat since
Old 11th December 2015, 11:52 AM
Johnmed's Avatar
Very helpful and logical Lee.
Thanks.
Old 11th December 2015, 12:46 PM
Johnmed's Avatar
After 50 mins driving the SoC is still 60%. I wonder if this would explain why the D3 has been unable to jump start other vehicles...
Old 11th December 2015, 02:44 PM
Yep ,sounds feasable
Old 11th December 2015, 02:47 PM
Symptom or cause?
Old 11th December 2015, 03:06 PM
Johnmed's Avatar
Symptom or cause?
The same error code for the battery regulation module was there before I bought the car mate. So I'm guessing it's not because I tried to jump start two cars.
Old 11th December 2015, 03:15 PM
Yes good point Paul with regards to Johnmeds car , with mine (your old un ) battery was brand new and was only getting the 60% SOC .
There was nothing wrong with orginal battery by the way........ just upgraded for the aux heater job .
Power upgraded and dpfs gutted now on the old girl ........ goes like the frekkin wind 42 mpg steady 70 mph ish now
