Fuel Rail
Can I remove the fuel rail?
If so, how? Does the full inlet manifold have to be removed to remove the injectors? I've got the fuel rail unbolted and the connections to the injectors off. Do I just pull the injectors out? Just wanting to remove the fuel rail so that I can get more access to the rear passenger side engine block hole as I need to put a strap through it. Cheers Andrew |
If you have pulled all the clips that hold the injectors to the fuel rail put them back.
Once the fuel rail is disconnected from the high and low pressure lines and the bolts have been removed just use a large screwdriver to gently lever the injectors out of the manifold. They are only push fit. Start at the front and work to the rear on either side at the same time.
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
superb!
Thanks again!! |
Bad news.
The injector cap snapped off on one of the injectors and is in the head somewhere. I'm going to finish the subframe swap and then i'm guessing i'm gonna have to go hunting for it in the head. So expect a thread asking for info on how to remove the head! My dad was popping the injector that came to pieces so he is pretty mad at himself. I dont really mind aslong as I'm able to fish it out. Good opportunity to polish the head and get everything nice and clean! |
