Help with ecu location pls
Still fighting with my auto light/wipers issue
No one knows whats wrong.....not surprised there I guess Could you guys point me ecu's location for above? Don't have a clue how to locate the fault Frustrated beyond frustrated All coding is correct, no faults, new rain/light sensor fitted I thought that the windscreen is incorrect but after close inspection all serial numbers are matching rest of the cars glass Did the s8 originally had sun visor, my next question? Properly |
This ECU is located behind the glovebox, next to or very near to the CAN gateway.
Part number is 4E0910279(revision letter) if you need a new one. hope you get it sorted
Thank you matty !!!!!!!!!
Hi Borys,
If all is fine with J519 (09 - Central Electronics) there maybe a fault with the wiper motor control unit J400 or wiring in between. J400 is a slave from J519 and controlled via LIN. The physical wiring between J519 and J400 is from plug C (that's the 32pin connector) J400 is one complete unit with the wiper motor. Have you replaced this in the past?
No never touched by me
Problem lies with auto lights as well, they are on all the time no matter if dark or day light Was hoping that there is an ecu which control both as the rain/light sensor |
Yes J519 decides whether to turn dipped beam on or auto start the wipers, hope you can understand this command path
Rain Light Sensor (G397) >>>LIN>>> sunroof electronics control (J528) >>>CAN>>> power supply control unit (J519) Auto Lights Switch (E1) >>> power supply control unit (J519) J519 then controls the headlights and wipers from data gathered from Rain Light Sensor & Auto Lights Switch. Hope that makes sense.
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 25th January 2016 at 01:18 PM. |
Another thought, is module 38: Roof Electronics (J528) coded correctly?
The rain and light sensor -G397 is coded in the onboard power supply control unit -J519. If the rain and light sensor -G397 is fitted the light sensor must not be coded in the roof electronics control unit -J528. You can test this by subtracting 256 from the coding value in 38: Roof Electronics. Note down the original value before changing!
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 25th January 2016 at 01:36 PM. |
Thanx Matty
I try myself otherwise will ask my tech to help and tackle it Or if there is a a8 meet in near future we could see whats what I'll let you know how did I do :-) |
Yeah, keep us updated.
This may be of use, it's coding of the rain / light sensor that relates to the glass you have. http://www.audi-portal.com/en/diagno...ors_17274.html
