Old 2nd March 2016, 11:20 PM
dhrf dhrf is offline
Default Hello from Argentina
Car
Audi A8 1997 Quattro 4.2 ABZ, OEM Xenon headlights
112k kilometers
the repair history include a timing and water pump change.
Timing belt cover rubber gasket is broken and you can see the timing belt
Bad?
can wait?
is normal?
Belt don't have sings of imminent failure
I have read many forums but I have not see this problem so I don't know how critical it is
Old 4th March 2016, 08:44 PM
Welcome to the forum. We are becoming very multi national!
The rubber seal on the cambelt covers is not a critical issue. Fix it when yiu have time but it wont cause engine failure.
CtL
Old 4th March 2016, 09:26 PM
ok thanks
is hard to troubleshoot this car......
Some things don't generate codes.
my biggest headaches
Car die after 30 minutes and only start after 12hs, it happened many times.
I was the fuel pump......
Small hydraulic leak from the steering reservoir, was small and did not pay attention to it for over a year.
ABS motor is under that and is not sealed, the leak kill it, I put a new sealed one.
Do to price and availability I use many VW parts after checking the numbers (front suspension, disk etc)
Do to age all engine connectors are cracked....
I run it hard and have some mods (I live in the 3r world...I want the benefit's)
The engine have happy days and not so happy, d4 a8 and s4 are the normal meal and can reach 276km.
Old 4th March 2016, 09:28 PM
CtL
I buy many parts form A8 parts
arm rest from a8 2002, and many others to have as old stock.
Old 8th March 2016, 08:46 PM
