Go Back   A8 Parts Forum > A8 D4 > D4 - Axles, Brakes, Suspension and Steering
D4 - Axles, Brakes, Suspension and Steering Brakes, Springs, shocks, steering racks, steering columns, suspension arms, wheel hubs etc.
Old 12th April 2016, 03:02 PM
Default Well this isnt good for a first day
Steering suddenly gone very heavy, barely turn it at all
run a scan nothing seems significant, anyone know what i should be looking at
Old 12th April 2016, 03:08 PM
Dare I suggest VCDS in case its some clever steering / drive select thing and it can give you a clue ?
Otherwise you're into mechanicals of steering fluid / leaks i guess ?
Old 12th April 2016, 03:18 PM
kungfupanda kungfupanda is offline
Can you take the engine cover off to see whether the auxiliary belt drives the power steering pump? If it does, check if it's in good condition and not come off any of the pulleys?
Clutching at straws here but it's a simple check to do.
Old 12th April 2016, 03:19 PM
tried vcds - cant see anything strange
Old 12th April 2016, 03:21 PM
wouldnt know what i was looking at
Old 12th April 2016, 03:39 PM
if the power steering has gone shouldnt i see something in vcds
Old 12th April 2016, 03:43 PM
Maybe not if its entirely mechanical....
If its really, completely without power, and turns ok at speed, then I would go with earlier suggestion of checking belts.
I would imagine if a belt was off, it would be really quite obvious with the bonnet up and engine cover off if the engine was turning but a belt was off or still..
Old 12th April 2016, 03:44 PM
But if the belt was off, you'd expect it to be driving other things like a/c or alternator. You'd expect to notice that....
Is everything 100% ok bar the steering ?
Old 12th April 2016, 04:14 PM
i can see one belt - looks ok and turns while engine on
cant see anything else
havent noticed anything else not working, AC seems ok
was thinking to check power steering fluid, found the cap but it doesnt seem to budge, is this a brute force screw on or is there a trick to it
Old 12th April 2016, 04:22 PM
Power steering cap might be tough to get off. Does it have a narrow cutout across the top to stick something in to turn?
To be fair, if you've bought from Oscar, I'd presume he'd take it back straight away to put any problems right.
