Old 19th April 2016, 09:26 AM
krazy_ivan's Avatar
krazy_ivan krazy_ivan is offline
Default 11*20 all around
small and quick question:
will 11*20 fit on a 2007 d3?
fit = dont touch anything anywhere
if it wont, what is the maximim wide i can use? 10*20 all around should certainly be ok - correct?
i really like it when the rim/tire comes outside of the car
the rim im looking at, for your info, is a rohana rc10 concave
(if anyone knows of similar deep concave rim which is less expensive, please tell me )
thanks in advance for your opinions / experiences
BR
I
Old 19th April 2016, 10:09 AM
krazy_ivan's Avatar
sorry forgot to add, ET would be 28 on that specific wheel...
Old 20th April 2016, 12:21 PM
krazy_ivan's Avatar
anyone?
test
Old 20th April 2016, 12:47 PM
depends on so many other factors - age of car and suspension type, se or sport suspension, what wheels and tyres you've already got on etc.
The best thing is to measure what your current gap and poke of wheel is on your current wheels and then put the info for your current and new wheels and tyres into www.willtheyfit.com
and then you can see how much more they will poke out and in vs your current fitment
Old 21st April 2016, 01:26 PM
krazy_ivan's Avatar
sorry, im a bit of an idiot, im an IT specialist (nuff said) how do i see if i have a sport suspension?
test
Old 21st April 2016, 01:51 PM
Press the 'Car' button and it will be displayed on the MMI screen.
Matt
Old 22nd April 2016, 09:28 AM
krazy_ivan's Avatar
thanks!
test
Old 24th April 2016, 10:29 PM
krazy_ivan's Avatar
so, i have a sport suspension (is that good or bad?)
i ran the number s on will they fit
on car documents says , on registration it came with 235/50 r18 101Y`(i suspect and 8J)
i ran numbers for an 10.5 wide rim, 20" and an ET of 27 ( http://www.nicheroadwheels.com/specs.cfm?id=5093 )
says 1% difference in circumference (ok i think) but im worried over the rim moving in closer by 1.5 cm )
Compared to your existing wheel, this new wheel will have an inner rim which is 15.8mm closer to the suspension strut. The outer rim will poke out 47.8mm more than before.
will this work??? i mean, without spacers
please let me know if you do
test
Old 25th April 2016, 12:32 PM
You will need to get your car up onto a ramp or get underneath and see how close the existing wheels are to everything and then add those figures on to the inside and outside of the wheel and see if it looks like you will have clearance - its the only way to tell without actually offering up the actual wheels and tyres
Old 25th April 2016, 01:32 PM
krazy_ivan's Avatar
mm, not really my cup of tea
luckily for me, i need to put the car in a serviceshop soon, change the filters, oil etc everything.
ill ask them to measure it for me.
even if they would come in to close, it could still be sorted out with a spacer as a last resort i guess
test
