Go Back   A8 Parts Forum > A8 D4 > D4 - Axles, Brakes, Suspension and Steering
D4 - Axles, Brakes, Suspension and Steering Brakes, Springs, shocks, steering racks, steering columns, suspension arms, wheel hubs etc.
Old 27th July 2016, 10:47 AM
Albert_Swafega Albert_Swafega is offline
Default Suspension Fault
2011 A8 3.0 rear has dropped, needs fixing quickly, so dropped in at the Dealer, but they can't look at it until tomorrow.
Just wondered if anyone had had this before or could give a reasonable guess as to the cause/remedy?
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4H0 907 553 C HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0096
Coding: 008001
Shop #: WSC 01236 210 01865
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_AU64.rod
VCID: 2CB2C93F4F04AF724986B1-8078
6 Faults Found:
677386 - Ride-Height System; Plausibility Error
C1046 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 197
Mileage: 171307 km
Date: 2016.07.25
Time: 18:30:20
677387 - Ride-Height System; Plausibility Error
C1046 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 197
Mileage: 171305 km
Date: 2016.07.25
Time: 17:57:45
677390 - Ride-Height System; Plausibility Error
C1046 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 194
Mileage: 171232 km
Date: 2016.07.20
Time: 20:46:57
403200 - Function Shut-Off Active
C10C8 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 19
Reset counter: 157
Mileage: 169652 km
Date: 2016.06.20
Time: 18:44:14
677124 - Ride-Height System
C1047 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 171294 km
Date: 2016.07.24
Time: 18:21:36
115968 - Functional Limitation due to Excessive Temperature
P178E 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 197
Mileage: 171307 km
Date: 2016.07.25
Time: 18:23:57
2011 A8 Executive 3.0 TDI Quattro
Old 27th July 2016, 11:08 AM
Sounds like a large leak or compressor on it's way out working overtime, overheating and shutting down. Compressors can often be revived with £25 repair kit but on 2011 car it's a bit early for it to wear out.
Old 27th July 2016, 05:51 PM
Thanks for the input, i do hope it doesn't cost me an arm and a leg.
I need it desperately, we're booked on a ferry with the caravan a week on Friday. Hope they get it done or i'm screwed.
Old 27th July 2016, 06:02 PM
I would concur it looks like large loss of pressure and pump working overtime, or pump failing so pressure not building.
Either way, if its at a dealer, I would suspect a pump or suspension strut parts alone are going to be nudging 4 figures.....
But, subject to them being able to get the parts swiftly, which on a current model I would expect, then it shouldn't be too big a job to get done, if they can get it scheduled in for you.
I'd love to suggest it could be as simple and cheap as a loose connection or fractured pipe but unless there has been some recent impact or past accident damage then the pipes do seem to have been proven over time to be pretty robust.
Old 27th July 2016, 06:06 PM
Quick additional thought - Just the rear has dropped? both, or just one side ?
If the front is holding ok, then perhaps the pump is fine, and you have a leak in one of the rear struts. Still not cheap though.
On the plus side, getting it seen to asap usually saves the pump from ultimately wearing itself out trying to pump up a car with a leak, and you're done that
Old 27th July 2016, 08:22 PM
Joe2.0E Joe2.0E is offline
Given the front is okay, it could be just a leak/fault in a valve block causing the air pressure to the rear of the car to drop.
Fingers Crossed for You.
Parts should only be 3-4 days away at most once they can diagnose the fault.
Old 28th July 2016, 11:00 AM
I did notice the rear off side down a little a couple of weeks ago, but now, both sides, but only the rear.
Just called them for an update, and it can't do into the workshop until tomorrow morning now, they're running behind.
Meanwhile, i'm ****ting it 'cos my Holiday is at risk
Fingers crossed, legs crossed, and even eyes crossed.
Old 1st August 2016, 05:37 PM
Well, they've got back to me today
Parts Needed:
1x Fuse
1x Relay
1x n/s Rear Bellow? Split because car dropped so low?
1x Compressor
Absolutely gutted, only bought it in March, first ever Audi.
So, on the plus side, they can get it done for Friday, so we get to go on hoilday as planned.
On the down side, bugger all spending money now...
Old 3rd August 2016, 01:32 PM
Thats very unfortunate as I've never heard of Suspension issues before on a D4.
I presume "N/S Bellows" is the strut/airbag which is likely to be the most expensive part of the job.
It would be worth asking for a goodwill contribution from Audi, especially if the car has a full dealer history and reasonable mileage.
Hope it gets sorted in time for your holiday.
Old 3rd August 2016, 06:30 PM
They've rang today, they've fitted the compressor (£1150+vat) and it's still the same, the bellow is only £38, so not the leg as they're nearly a grand I'd of thought from audi.
They're back on it 1st thing, my bill at this point is approaching £2.5k
