Go Back   A8 Parts Forum > A8 D4 > D4 - Transmission
D4 - Transmission Gearboxes, diffs, drive shafts.
Old 14th August 2016, 06:45 PM
damtom85 damtom85 is offline
Default D4 owners, feedback about transmission needed
hi
I'm wondering if any of you noticed any issues with transmission when engine cold. I find gear changes quite rough while engine is still cold. When it reaches normal working temperature it gets smooth. l know that when transmission oil is cold it can cause higher friction. I have 8hp55a gearbox in my car and I found thread on BMW forum regarding 8hp55(letter 'a' in 8HP55a indicates use only for Audi as it has quattro feature). BMW owners have the same views about that gearbox, harsh when cold.
what are your view about this?
Audi A8 D4 4H 2012 3.0tdi Quattro 8spd ZF 8HP55a
Old 14th August 2016, 07:11 PM
paulrstaylor paulrstaylor is online now
Not an issue that I have noticed on mine......it does seem to hold gears longer when cold, presumably to aid warm up?
Old 16th August 2016, 07:18 PM
Joe2.0E Joe2.0E is offline
My 2011 3.0TDI can be quite rough when cold, most noticeable when selecting reverse. I have had the ATF changed and it didnt make any difference.
By comparison my old 6 speed D3 was smoother when cold but nothing as "Clever" in terms of seamless/fast changes you get on the D4.
Old 16th August 2016, 08:24 PM
If its a DSG box, there's your answer.
Old 16th August 2016, 08:52 PM
It isn't a DSG box.
Old 18th August 2016, 05:36 PM
pete-p's Avatar
pete-p pete-p is offline
The 2014 3.0tdi I'm using at the moment is perfectly smooth when cold, same as when warm.
Cars...
Old 19th August 2016, 11:43 AM
Mines silky smooth, if it didn't have the gear numbers on the dash I probably would have to keep a close eye on the revs to see changes, not that the revs ever build up to much....
Old 19th August 2016, 03:24 PM
It isn't a DSG box.
So what kind of box is it? Does is pre-select the gears?
Old 19th August 2016, 06:26 PM
It's an eight-speed auto, believe it is a ZF-8HP box.
https://en.wikipedia.org/wiki/ZF_8HP_transmission
Old 19th August 2016, 06:29 PM
I should add, although it a slush box, it is very intuitive and smooth and never seems to be in the wrong gear of have a pause for kick-down.
Perhaps partly due to the additional ratios over the older 6 speed, but also likely due to the integration with the navigation system, meaning it can change down as you approach a bend for example!?
