Go Back   A8 Parts Forum > A8 D4 > D4 - Interior Electrics
D4 - Interior Electrics Airbags, Sensors, climate modules, instrument clusters, switches etc
Old 22nd August 2016, 09:09 PM
Default Retrofit heated steering wheel
So the one option I decided I wanted that I don't already have was a heated wheel ready for the no doubt now unseasonably mild winter (if it is warm, you can thank me!), I have managed to source a heated wheel and switch and looking at Elsa I need a new slip ring and I am good to go.
Looking at VCDS I currently have 4H0 953 568 A fitted (module 16), does anyone have the correct part code for a slip ring to support both ACC and a heated wheel, I don't have lane departure warning.
Thanks in advance
Old 24th August 2016, 10:56 AM
The only slip ring I could find is 4H0953568H which supports heating (PR-1XT/2ZD) ACC is supported on the steering col. combi switch assembly.
Matt
Old 24th August 2016, 12:00 PM
Edit: Just read in your original post you've got the switch
Also, it shows a different part number for the switch for steering column adjustment, just thought I'd let you know.
4H0953551A - heated
4H0953551B - non heated
Matt
Old 24th August 2016, 08:26 PM
Thanks for the reply, has confirmed my thoughts I needed a H suffix slip ring, will now watch ebay.de to wait for one at the right price hopefully before the winter starts!!
I got a wheel, with cowl and switch for €165 which I'm happy with, the slip rings seem to sell for between €40 and €150 depending on the seller, so happy to wait for the right price as I certainly don't need heat in this weather!!!!
Looking at the wiring diagram, I may need to run a wire from the switch to the control module if it isn't already in the loom, that aside looks like pretty much plug and play.
I've never been able to work out how to get a part code based upon PR code, so thanks again
Old 26th August 2016, 08:23 PM
damtom85 damtom85 is offline
can you explain me where from u both taking this information, what elsa you using and where I can get one, thanks
Audi A8 D4 4H 2012 3.0tdi Quattro 8spd ZF 8HP55a
Old 27th August 2016, 05:05 PM
Search ELSAwin on google or ebay
Old 27th August 2016, 05:08 PM
Looking at this advert I am wondering if 4H0953568B will work, it looks to have the right connectors?
http://r.ebay.com/5GpT3D
Old 27th August 2016, 05:44 PM
Looked up that part and there's no PR codes linked, unfortunately can't say if it will work.
Matt
Old 27th August 2016, 09:18 PM
Thanks for checking, I may well take a punt on it anyway. I suspect that B was the original part code to include heating, and has been superseded by H....
Old 27th August 2016, 09:56 PM
That was in the back of my mind that B had been superseded. Hope the punt comes good.
Matt
