Retrofitted full size steering fluid reservoir
One day, one job
Retrofitted full size steering fluid reservoir from cars with self levelling rear suspension. It has 2.5+ liters extra capacity. I can now flush without disconnecting pipes -- just suck all fluid out and fill it fresh. Since system capacity outside the tank is less than 1.5 liters, 2-3 changes like this, each followed by a bit idling, will change almost all fluid in the system. It also fills that empty space to the right of engine a bit better. £15 from A8 Parts . Before: After:
I'd rather drive on left Last edited by notorious; 29th October 2016 at 08:57 PM. |
Good idea and a neat solution. I have done it and its a messy job with the possibility of running it dry so the oversize tank is a great idea - but many aren't so fastidious about changing the fluid as you are! Neat, clean and tidy though as always Sergei
2002 D2 S8 – Ming Blue, Valcona leather, Vavona wood insert, solar sunroof (to be fitted), Heated rear seats, extended leather pack, 18” Avus, ski hatch, Bose, auto dim rear view mirror, rear blind. Last edited by David's8; 29th October 2016 at 08:53 PM. |
