Old 14th August 2018, 12:32 PM
Readie Readie is offline
Default central locking vacuum control pump
Hi all have started this post following my new member intro post.
The central locking works on the key but not on the remote. It also seems that the alarm is not engaging.
I am told by the vendor (who had the central locking tested) that the problem is the central locking vacuum control pump.
Does anyone have any experience of this, of changing this or any other thoughts or comments.
Thanks.
Old 14th August 2018, 12:38 PM
That sounds more like a coding issue. If it locks on the key then the pump works.
Coding could be:
1. Remote key not coded to car.
2. Car not coded for enabling remote locking or alarm or both.
3. Something else.
If you have (or someone near you has) VCDS a scan might show more (e.g. errors); it would also enable you to check the central locking module coding.
As the old adage goes, the first tool you buy for a D2 is VCDS.
Old 14th August 2018, 12:45 PM
Thanks HP. so next question...
Where do I get and what type do I get, of a vcds..?
current:
- newbie to audis, 2001 s8 purchased aug 2018, changes have begun... centre box delete and straight through pipes.
- e9 csl 1972, fully restored, silly bits to finish
- 2002tii 1972, 'bought by accident' and work in progress
- toyota hiace camper, just repainted in gulf racing colours and now getting used
- honda c90 custom cub, ' bought by accident'....there seems to be a them here..!
(Not so) Recently departed:
- very sadly sold to fund the e9....BMW e28 m535 white 1986, owned 12 years, I loved that car.
- red mk1 vw golf gti, fully sorted: resprayed, flash red, mk2 1800 16v conversion, uprated brakes, shocks, leather interior,
- 1986 Saab 900 turbo convertible sold to get Audi on 'one out, one in' rule imposed by missus...not really adhering to the rule at the moment as can be seen..!
Old 14th August 2018, 10:28 PM
Thanks for the messages guys.
Sorry but I am new to this type of diagnostic stuff as you will guess from the cars in my signature !!
I have now looked through some of the paperwork and uncovered a couple of printouts from may last year which were carried out about 20 mins apart.
The earlier one has a few fault codes for different ‘addresses’. The print out 20 mins later has all the ‘addresses ‘ clear apart from address 35 - central locking which has 27 faults per the pictures below.
How do I go about sorting this out?
If I took to a garage would they know what to do ?
Comments much appreciated.
ID:	19911   Click image for larger version
current:
Old 15th August 2018, 06:16 AM
mannyo mannyo is offline
The printout is from VCDS, first thing is to have all those codes cleared which needs vcds and then drive the car for a bit and see what comes back.
Manny
Past
Old 15th August 2018, 07:43 AM
thanks mannyo.
I think that is exactly what the owner did back in may 17 given I have the two read outs one with lots of fault codes across the board in many areas/addresses and then another printout I have 20 mins later showing 'all clear' apart from the ones under the central locking section as shown in the picture ...??
current:
Old 15th August 2018, 07:56 AM
That was then, this is now, so those details aren't worth much really.
Though they do tell you the car was in a crash severe enough to trigger the unlocking of all the doors.
Hopefully there's someone near you that has VCDS.
Depending which version of VCDS was used clearing codes is not always that reliable, especially if done "globally".
I have a full genuine cable and I still clear codes by going into modules individually, then go back and verify.
Old 15th August 2018, 09:51 AM
You would almost certainly save yourself more than you'd spend at a garage by using VCDS to reset and verify those codes that are genuine and taking advice here BEFORE going to a garage that was qualified to work on an A8.
And equip yourself for the future. (For VCDS you need a genuine lead which costs, a software download and a Windows laptop)
Looking at those 27 errors, my thoughts are:
First 5, information, will go away.
Next 12, wiring issues (shorts etc.) probably due to the crash. Are they fixed?
Next 4, information, will go away as keys are used.
Next 3 (alarm horn), you might need a replacement. DIY job, though a bit inaccessible (deliberately) or live without it.
Final 4. No idea, do they mean anything at all?
It could indeed be that the central locking unit is damaged, but if it works from the key blade, unlikely. Others may/will have different opinions.
Old 15th August 2018, 10:08 AM
I would not worry too much about opened due to crash fault code if there are no obvious signs of crash damage and repair I have had it come up on mine while in my ownership without crash.
It does show adaption limit surpassed for all 4 keys so i would first try new batteries in keys and try to re-match keys to car.
Code:
Matching procedure for new remote keys
‒ Unlock the vehicle from the outside via the driver's door lock
‒ Switch on the ignition (using additional key).
‒ Lock vehicle from outside with the key to be adapted by way of the driver's lock door.
‒ Within 5 seconds press "unlock" key of remote key until next memory position is reached (3x in example).
Each time the button is pressed the hazard lights will flash to confirm.
‒ Wait 5 seconds.
‒ Then press "unlock" key again. This unlocks the vehicle =>key has been successfully matched.
‒ Switch off ignition and remove ignition key.
‒ Check function of new remote key.
Old 15th August 2018, 10:18 AM
I get adaptation limit all the time, usually (I think) due to the keys getting squeezed in my pocket and the buttons pressed.
It doesn't seem to affect remote lock/unlock though.
Just a tip. When doing any of those procedures as described by Ainars, have the drivers window open so you can get at the key in the ignition.
