Old 21st November 2018, 06:36 PM
RS6's Avatar
RS6 RS6 is offline
Default Post a photo - FE wheels/Aftermarket & lowered
Getting new coilovers fitted next week on the D2 not sure what ride height to go with! spacers are now fitted which looks really good 20mm back 10mm front, so im interested to see what ride height people are going with daily, i want it dropped a bit but not with wheels tucked in the arches, post up if you have different springs or coilovers setup be great to see what people are using!
Abarth 500 Esseesse - Sold
RS6 Avant Black - Stolen
Mercedes Benz CLS 500 - Sold
Corsa VXR Nurburgring - Sold
RS6 Avant Grey - Sold
Seat Leon Cupra R - Sold
Old 21st November 2018, 07:04 PM
Which coilovers are you going for? Top of my head, I can only think of mine, Neil's and Ricky's that are lowered, and Lee's wrapped PF on air.
Mine is the perfect height IMO. Its a nice driveable height and looks perfect, although I am pretty careful over rough roads. I've never actually measured how much lower it is tbh - I think probably 30mm front, maybe 20mm rear. I have Bilstein B6 and Intrax springs which were initially too low at the rear so I lifted them up with an aluminium spacer to the height below. Neil's is only lowered at the front as well.
Compared to Mike's stock Murple:
ID:	20477   Click image for larger version
ID:	20478   Click image for larger version
Old 22nd November 2018, 08:47 AM
Mine on the 20" FE, Bentleys and the Kahn wheels
Coilovers on front only as couldnt get the 21 x 10.5" 295 Kahn wheels on the rear if I lowered it any
The last pic is with the Kahns on before the coilovers went on
The fronts are currently probably just a tad too high, I was aiming to equalise the arch gap, but I have issues where I am driving the car for daily use, with driving over speedbumps and parking near kerbs if I go much lower
ID:	20480   Click image for larger version
ID:	20481   Click image for larger version
ID:	20482   Click image for larger version
ID:	20483   Click image for larger version
Old 22nd November 2018, 09:24 AM
RS6's Avatar
RS6 RS6 is offline
Gone with the cheaper KW ST X Coilover kit also need to replace the suspension arm bushes in the upper and lower front suspension arms so doing that as well
Old 23rd November 2018, 09:36 AM
RICKY D's Avatar
RICKY D RICKY D is offline
You’ll do well with the ST units James, they’re made by KW and built to the same spec as the KW V1’s without the inox front struts. Quite a few guys in the USA run them and the reviews are all positive. The only issue people have with them, which is the same as the KW V1’s, is the rears don’t always go as low as people want.
This was when I first had them fitted. The rears are maxed out on the lowest setting approx -30mm,and the fronts down about -35mm.
This was taken about a month afterwards and the fronts settled down another -5mm or so, which is around -40mm overall. The rears didn’t really change. The rears are quite sensitive to road angle; however I’ve noticed that on uneven ground the rear can look +/- 10mm depending on how uneven the surface is.
2016 S5 Coupe Black Edition - Ibis White
Old 24th November 2018, 10:02 AM
What great photos of lurverly cars! Can’t beat a bit of D2 porn on a Saturday morning!
Old 24th November 2018, 03:23 PM
Yep. Your car looks amazing
Old 24th November 2018, 05:23 PM
gninnam gninnam is offline
+1
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 24th November 2018, 05:55 PM
Norretal's Avatar
Norretal Norretal is offline
I'm somewhat confused, The Laird hasn't posted pics of his D2?
Audi TT - 2015 - Ultra
Old 25th November 2018, 11:19 AM
Regulus Regulus is offline
He probably ment "your cars"
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
