Old 18th October 2020, 06:02 PM
NightOwl NightOwl is offline
Default Air suspension question
Bigger trucks and construction machines have a container with anti-freeze to stop corrosion and prevent ice in the systems for brakes and air suspension, and the air tanks needs to be drained regularly to get water out.
So, how does this work on a car with air suspension like the D3? It doesn't have the container with anti-freeze as far as I know and there isn't any manual drain valve for the air tank. Is there some kind of air dryer? Automatically drain valve? Tried to do some search online, but couldn't find anything useful...
2006 Audi A8 3.0 TDI Quattro Sport
A8 W12/S8 Brakes front and rear (385mm/335mm)
Focal and JBL speakers, Helix amps
S8 anti-roll bars front and rear
Complete rear LED taillight
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
Old 18th October 2020, 06:41 PM
Joe2.0E Joe2.0E is offline
Compressor has a small built in dryer as air volume is very small
Link below to a repair kit;
https://www.google.com/url?sa=t&rct=...ZfZWFB8XjyoN80
Old 19th October 2020, 11:28 AM
Ok, so this dryer is so effective that there is no need for a drain valve on the air tank?
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
Old 19th October 2020, 01:33 PM
If there are no leaks then the amount of air being pumped is very little, compressor comes on very rarely. On the truck with pneumatic brakes air is released every time you brake and fresh need to be pumped in.
