Old 29th October 2022, 07:03 PM
homer simpson's Avatar
Default Fault code after replacing oil filter gasket
Evening all, finally got around to tackling this and it wasn't too bad. Intake manifold off, cleaned everything, replaced gaskets and everything put back together. On start up, it seemed ok (no warning lights) so turned it back off whilst I cleaned some other bits. On final start up, MIL was on and VCDS gave the following code:
001632 - Intake Manifold Tuning Valve Control Circuit (Bank 1)
P0660 - 004 - Elect. Malfunction
Is Bank 1 on the right hand side as you stand in front of the car?
I have checked all connectors and it's all plugged in. When the manifold was removed, I cleaned it carefully and didn't remove the motors or arms so as not to disturb the position. The flaps were removed around 3 years ago and never had an issue. Does this seem like a motor issue or an electrical one?
Old 29th October 2022, 07:07 PM
Bank 1 is on the right side as you sit in car
Old 29th October 2022, 08:50 PM
S81 S81 is offline
As a matter of interest was there much carbon in the valve ports ,i'm guessing you got the cleaned when you deleted the flaps ?
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 29th October 2022, 09:16 PM
Thank you
Yes there was and yes it was carbon cleaned when the flaps were done. On inspection now, there was some minor build up on the valves.
Am I right in thinking you shouldn't be able to move the motor arms by hand?
