Old 11th October 2010, 01:00 PM
GlynH GlynH is offline
Default Shopping list for 2001 S8 Service items please?
This is a tall order I know as I need part numbers for service items and cambelt change.
I have tried a couple of Audi dealers but they don't want to divulge part numbers. My g'f works with VAG and so might be able to get a good discount but I won't know till I've tried and she needs part numbers for that!
With the cambelt I also want to replace everything there while the front of the car is off including tensioners, pulleys, water pump, thermostat, gaskets and whatever else is lurking under there...obviously if anyone can help with ETKA/ELSAWin then please feel free to pm me as I know this is a lot to ask!
List as follows - please feel free to add any other items I may have missed that it would be prudent to change.
Spark plugs
Air filter
Oil filter
Fuel filter
Cambelt
Water pump
Thermostat
Serpentine belt
Any other tensioners/dampers/pulleys, gaskets/seals, bolts etc. etc?
There are also some other parts that don't really belong here so I will ask in the appropriate forum(s).
Thanks & kind regards,
-=Glyn=-
Old 12th October 2010, 11:35 AM
Glynn,
I'll post some part numbers up tonight. Can I have the Engine and gearbox codes plus your VIN for your car please? By PM if you want is fine.
Old 12th October 2010, 05:23 PM
Reffro Reffro is offline
I've got a couple of extra's that are missing.
Pollen filters
Brake Fluid
Old 13th October 2010, 04:55 PM
Originally Posted by GlynH View Post
Spark plugs - b101000054AD (But buy the bosche equivalent as it 1/2 the price)
Air filter - b 077129620d (but pay extra for the K&N reusable, much better)
Oil filter - b021115562
Fuel filter - b441201511C - OEM comes as a kit with all washers etc
Cambelt - Belt = b078109119H; Relay roller b077109244C (x2); relay roller = b077109244E; Belt Tensioning damper = 059109479B; tensioning lever = 077109485C
Water pump - 077121004P; Gasket 078121043A
Thermostat - 077121113C; round seal = N90136802
Serpentine belt - b07793137Q
Don't try holding me to account. But you should be able to price what you need from these.
Old 14th October 2010, 07:11 AM
The burden is on your shoulders now Mike!
Seriously...thanks for the detailed replies here and in my other threads.
I'll get these priced up...you're one of a kind!
-=Glyn=-
Old 14th October 2010, 07:18 AM
-=Glyn=-
He sure is. . . . mainly due to his special sock. .
Seriously though Mike needs a medal for all his hard work and he is truely THE Librarian
Old 14th October 2010, 07:39 AM
Special sock?
Real men wipe it on the curtains...apparently.
Clever men check to ensure they are not venetian blinds first...
-=Glyn=-
Old 18th October 2010, 04:45 PM
For anyone else who may come looking in this thread for part numbers there appear to be a couple of superceded part numbers and the missing pollen filter;
Cambelt = now b078109119J (not H)
Thermostat = 077121113D (not C)
Pollen Filter = 4D0898438A
Everything else looks spot-on although the water pump looks expensive
I know how Librarians like to keep their records up-to-date...
-=Glyn=-
