Old 7th November 2010, 09:53 PM
r8dream r8dream is offline
Default Audi 's Alusil 4.2 Engine Rebuild Resources part 1 and 2
when audi's futuristic glass cylinder bore fails,(or why to change your oil every 5000 miles not 20000). part 1, website links.
full oem 100 page recon manual (2.6mb)(not to be done in your backyard,thou i might try)
http://www.electrosil.com.au/KS.pdf
oem block design(yes it's rocket science)
http://www.kspg.com/fileadmin/media/...sil_audi_e.pdf
more kolbenschmidt info in german though
http://www.schule-bw.de/schularten/b...s_und_Auto.pdf
new oem honing tips(squeaking noises when using drill?)
http://www.ms-motor-service.com/xima...022_en_web.pdf
honing paste(diamond paste ,what else cuts glass)
http://www.ms-motor-service.com/xima...018_en_web.pdf
oem tips for honing (polishing the glass)
oem tools for honing (only pages 29-34)
http://www.ms-motor-service.com/down...931-02_WEB.pdf
piston damages(don't keep driving while misfiring)
http://www.ms-motor-service.com/xima..._leseprobe.pdf
why oil consumption(change your oil more)
why cylinder bore problems
http://wardsautoworld.com/ar/auto_bo...rybodys_ideas/
nikasil and alusil defined
http://www.aera.org/ep/downloads/ep4/EP10-2008_18.pdf
sunnen honing techniques
http://www.aera.org/ep/downloads/ep2...2008_20-26.pdf
sunnen honing equipment
http://www.sunnen.com/graphics/asset...4ccd4d8c9d.pdf
best uk bore finisher, capricorn
http://www.capricorngroup.net/upload...ldMagazine.pdf
best racing cylinder liner companies ,capricorn, la sleeve, darton.
http://www.capricorngroup.net/upload...Technology.pdf
race engine technology mag. spyker lemans audi 4.2 s8 racing engine
http://forums.quattroworld.com/a8/msgs/36760.phtml
audi self study program for 4.2 40 valve belt drive engine part 1 and 2, english available by pm.
http://www.volkspage.net/technik/ssp/ssp/SSP_217_d1.PDF
http://www.volkspage.net/technik/ssp/ssp/SSP_217_d2.PDF
audi 4.2 fsi rs4 self study program
http://www.volkspage.net/technik/ssp/ssp/SSP_377.pdf
audi rs6 4.2tt ssp
http://audi.service-bg.com/articles/...44-audirs6.pdf
links for part 2 below
audi v8 rods available off the shelf.
http://www.rosten-performance.com/pa...audi_v8_motors
http://www.pureperformancemotorsport...products_id=40
http://www.034motorsport.com/engine-...2kggtrrglqktk5
http://jhmotorsports.com/shop/catalo...6893561f6cea0f
http://vastperformance.com/shop/inde...85392714e59be9
http://www.intengineering.com/Integr...17378-1-2.html
schrick camshafts for the chain drive 4.2 40v in the s4, 2 different profiles
http://www.avl-schrick.com/dat/MK/Sc...202009%20D.pdf
http://www.euroring.com/products/
http://www.woessner-kolben.de/
http://www.bobistheoilguy.com/forums...1173767&page=1
http://www.lindseyracing.com/LR/Parts/ENGINES944T.html
http://www.lnengineering.com/whynickies.html
http://www.944enhancement.com/html/e...machining.html
http://www.racersedge-inc.com/
mrc rs6 4.2tt 700hp
http://www.youtube.com/watch?v=1M-37ED5oMY
alusil machining video
http://www.youtube.com/watch?v=-ek5qv8Nmg0
audi/Volvo 5 cylinder block 720hp r8 v10 5.2 fsi head? on fire
http://www.youtube.com/watch?v=df-yU-g6ljE
dart heads block 2000hp
http://www.youtube.com/watch?v=89kqqHPb9bc
http://www.mt-llc.com/About/about.html
http://www.eurospecsport.com/product...l-engines.html
http://www.sunnen.com/default.aspx
http://www.jepistons.com/Default.aspx
all s4 4.2 motor failures list
http://www.audizine.com/forum/showth...pdate-10-13-10
http://www.worldcastings.com/product...rt-blocks.html
http://www.dartheads.com/products/engine-blocks
http://www.larryspower.com/engine/Darton_Volvo.html
all qualified alusil machine shops/rebuilders in germany
http://www.amz.de/fileadmin/epaper/a...sl/pdf/126.pdf
all machine shops/garages with alusil experience in the uk
Capricorn-group
Turner engineering lingfield
Boost performance
Headshopukltdwarrington.co.uk
W drake bradford
Sps engines
Gosnay’s engineering romford
notes for rebuild are here http://forum.a8parts.co.uk/showthread.php?t=2290
Old 7th November 2010, 09:59 PM
Top reference library resource John. Thanks. Added to Sticky.
Old 8th November 2010, 02:27 PM
Thanks John! Ive cancelled all my (expensive) magazines - now all you need to do is find that much monthly for us all to read!!
Old 15th November 2010, 07:43 AM
Default audi 's alusil engine rebuild resources part 2
Some observations about Audi’s 4.2 v8 alusil engine
From 1995, when production of Audi's alusil 4.2 v8 started, it took Kolbenschmidt (block manufacturer)and mahle(piston manufacturer) 11 years to release the (reconditioning of aluminum engine blocks) manual, first edition 2006. before this time sunnen was providing the information about exposing the silicon glass cyrstals with their diamond paste. There was some confusion from the manufacturers about using chemical etching to expose the surface in the begining.
Audi has also hidden most of the 4.2 internal engine specifications, like piston to wall clearance. There is also confusion when using forged pistons of 2618 or 4032 alloy because their different expansion rates and wall clearances. 4032 alloy expands 18% less than 2618 and therefore can run tighter clearances; Wossner recommends .0020-.0025? and only makes pistons from 4032. You could run a looser clearance on them and not hurt anything. Someone using the standard audi oem spec. and boring for stock piston clearance while running a 2618 is going to stick them. No question about it. Je-Pistons makes 2618 alloy pistons which need at least .0030? clearance. Another issue is ring gap, if the spec says .008 to .016 . If they were to tight, as the ring grows, the gaps come together and you can kiss your cylinders good bye. Better to gap on the larger side and error on the side of safety.
Bmw, Mercedes and Porsche also used alusil for many years and the bmw v12 with cast pistons used a very tight piston to wall clearance of .0015? or less.
So many alusil engine rebuild failures are due to wrong piston to wall clearance issues and using rings that aren’t using a barrel shaped face. the wrong iron/graphite skirt coatings can also lead to scouring.
Audi will not sell you oversize pistons or rings,(disposable short block) except maybe for the 4.2 rs6tt (elsawin), and Mahle who made the 4.2’s originals will charge you a fortune for custom sizes with long waiting times (even goezte stopped selling 4.2 aqh belt drive rings this year). kolbensmidt says in the reconditioning manual at 3.1.2 that "the availibility of oversize pistons is determined by their demand and sales potential" so no demand or sales potential because its "irreparable". Euroring sells abz and other 4.2 rings.
At the moment Woessner-Kolben is probably the best proven alusil custom size piston maker due to, being a German manufacturer (close to the source), skirt coatings, using barrel shaped rings and only 4032 alloy. Je-Pistons, jhmotorsports and 034 also have pistons for the alusil 4.2.
How many pistons have been thrown away by the alusil engined Porsche 944turbo, 911 and 928 racers like Lindsey Racing, Racersedge-inc or 944enhancement (all alusil/wossner specialists)learning about glass cylinder honing. The porsche racing crowd has the most experience in alusil engine rebuilds. Their advice is, make sure you measure the bores cold when checking them through the boring/honing process. The heat generated in the boring/honing makes the cylinders grow (can begin to simulate a up to temp engine) and they must cool down first. Otherwise your too tight on the clearance. About Darton's MID sleeves, from an expert. Sleeved engines have always had their share of failures, it is usually because the shop that did the work did not have experience in that particular block and how to sleeve it. The MID sleeves need to be installed with a very high level of accuracy, you can’t do that with a ‘standard’ machining process, it needs to be a programmed CNC operation. Its not cost effective to do this for one block.
Some go successfully to nikasil plating like Ln-Engineering. Millenium Technology is a respected nikasil plater of alusil blocks and at least one 4.2 builder has used US-chrome(usnicom.com). However Capricorn is plating the 4032 alloy liner and not the alusil block itself in the Lemans Spyker.
Why does audi tell its customers to change the oil every 20000 miles (longlife service), when the oil laboratories (bobistheoilguy.com) proved that fuel dilution on a 4.2fsi rs4 was 5% after 6000 miles?(the oil’s useful life finished). however they found fuel dilution on the non fsi 4.2 much lower. 20000 miles is still crazy.
Alusil silicone crystal walls are very abrasive on the rings with many 4.2’s in Germany over 200000 kilometres(120000 miles) burning enough oil to be called a 2 stroke.
So how to keep our beloved Quattro’s running with the disposable-glass short block.
Kolbenschmidt mentions the audi 4.2 block in the reconditioning manual at 3.1.3 "irreparable aluminum engine blocks?" when it says "one renowned manufacturer advises that certain engine blocks must be replaced completely if the bearing caps of the main crankshaft bearings are opened" and then says we know competent machine shops consider it a "special challenge" to rebuild these blocks, indeed! Maybe irreparable also because of the narrow bore spacing of 5.5-7mm used in the fsi and belt drive 4.2. For comparison the porsche cayenne 4.8 block is best with at least 10mm between bores.(audi engineers were trying to make the 4.2 front to back narrow as the four wheel drive Quattro system makes it hang over the front wheels. Audi moved the engine back 5” within the chassis in 2007 with the S5’s mlb platform. This was accomplished by changing the position of the front differential and the clutch inside the gearbox/transmission).
The tight bore spacing makes it difficult to put in new liners/sleeves due to thinness between cylinders. this also makes it difficult to obtain big reliable hp/torque numbers when supercharging/turbocharging the 4.2. The exception to this is rs6 4.2 tt block, (which uses the same bore spacing ,with water jacket modifications and even crank/rods/pistons interchange with the belt drive 40v 4.2, although pistons are 9.1-1cr instead of 11.1-1cr in the s8 4.2)which when modified, regularly make 700+hp in Europe. Some even have 300000 kilometres(180000 miles) on them. It’s a shame the 01e 6 speed manual doesn’t directly bolt up to the rs6’s slightly different bolt pattern on the block, though someone is selling an adapter plate with starter motor kit.
From all audi's NA 4.2 v8's, the 32 valve belt drive in the early s8, the 40v beltdrive in the facelift s8, the 40v chain drive inthe s4 and the 32v fsi in the rs4, the belt drive 4.2 40 valve is the toughest block casting to build upon, confirmed by mtm, the best audi tuner.
We don’t hear much about damaged rs6 4.2 blocks due to the low production numbers of 6000 compared to A8/S8 d2 4.2 -100000 in 8 years of production, but how many damaged a6/s6 4.2’s and s4 chain drive 4.2’s in the audizine forums engines failures list.
Now that two of the best liner/sleeve companies are involved with the 4.2; La-Sleeve using ductile iron and Capricorn-Group using nickel-ceramic plated aluminium sleeve on the Lemans Spyker NA 4.2. I hope that rebuilding 4.2’s for increased power on a large scale will become more affordable. Currently only one rebuilder (Eurospecsport) is offering off-the-shelf 4.2 engines. Darton even sleeves an inline Audi/Volvo 5 cylinder block that kms VanKronenburg in Holland uses to make 700+ hp.
Will the problem of 4.2 piston scouring fill junkyards with dead Audi’s in the next 5-10 years. Ideally (in the future maybe) custom block manufacturing companies like Dartheads and Worldcastings (where 1-2000hp V8’s originate, crazy americans) might sell new redesigned 4.2 blocks (don’t know how with that bore spacing) or crate engines even, for boosted applications. Normally they only sell Gm/Ford blocks but recently have started making custom 4 cylinder Honda blocks(strange?). Only problem with gm/ford blocks, is to support 1000hp they are 5” longer(due to bore spacing) than Audi’s 20” 4.2. The 500hp gm ls7 engine in the z06 corvette even averages 21 mpg, same as my s8’s mpg although s8 is 300kg’s heavier. Lets face it a 1700kg car needs 450ft/lbs of torque to get moving and 4.2 litres can’t make that without forced induction, example rs6tt.
This insanity is leading to my conclusion and maybe the next Frankenstein development for my S8 will be the GM ls3 crate engine with the S5's manual transmission.
all links for referenced companies have been added to part one
Old 15th November 2010, 08:02 AM
You're like the rain man or something John, thats an awesome post excellent reading. Although i think i'll leave mine alone and just put oil in the top when it burns it.
Old 15th November 2010, 08:48 AM
thanks for the compliment dezzy, you sussed me out 100% ,
unfortunatley that's what being in a coma does to someone.
no offence taken, john
Old 15th November 2010, 12:11 PM
No offence meant mate (takes foot out of mouth) I did enjoy the read it’s nice to have a (slight) understanding of the dark arts of Audi engines, I say slight because I’m not cleaver enough to understand it. If it has more than 8 valves and no carb’s I’m screw’d
Old 15th November 2010, 08:04 PM
don't worry mate, i'm not clever enough to write it either. but some how,
after one week thinking and compliling sources for one year. there ya go, bob 's your uncle.
Old 24th April 2011, 08:56 PM
Capricorn-group
Boost performance
W drake bradford
Sps engines
Update on John's post, Turner Engineering don't do anything but Landrover engines. I just e-mailed them about honing an ABZ.
Old 26th April 2011, 08:44 PM
yes mike i know they rebuild landrover engines, but they are the best lr v8 "alusil" block rebuilders and therefore have alot of experience and the best eqipment (sunnen) to hone alusil blocks. i think if you ask they would do the audi block. there are probably less then 10 machine shops with this experience in the uk. capricorn in basingstoke is still the best, as they did the spyker lemans cars.
