Old 30th July 2011, 07:26 PM
s2_bo s2_bo is offline
Default Alarm going off on its own
My S8s alarm has started to play up a bit, It goes off on its own for no apparent reason about 20 mins after its locked and then keeps going off every 10 mins or so until the car is unlocked....
Is this common if the alarm battery starts to run low? I mean the one thats under the carpet / left side passenger foot well...
I haven't tried to disable the interior sensors yet to see if they are kicking it off, i will try that tomorrow.
Thanks.
bo
Old 30th July 2011, 07:42 PM
If you have VCDS you will see what triggered it in fault codes and investigate further accordingly. Could be bad connection for door, boot or bonnet switches.
Old 30th July 2011, 08:03 PM
Thanks, i have to get a new cable as my last one was playing up.
Its a bit more tricky as im using a mac and even when booting in windows the USB/serial drivers where not working properly with the rosstech software.
Maybe a new cable will sort that out though..
Thanks again.
Bo
Old 30th July 2011, 08:19 PM
Thanks.
bo
Er, there shouldnt be any batteries or alarm components in the passenger footwell...
