Old 9th March 2012, 01:28 AM
aTOMic's Avatar
aTOMic aTOMic is offline
Lightbulb Link to my first VAGcom scan! (Part 1)
Rather than post this giant data dump within the many threads it's going to precipitate, I decided to stick it here in its entirety and only put the related excerpts in those threads. good idea, huh?
And its 2x too long per the forum's software! I'll delete some unnecessary stuff (dashes and spaces) and split it in two.
Thursday,08,March,2012,13:54:13:64698
VCDS Version: Release 11.11.2
Data version: 20120126
Chassis Type: 4E0
VIN: WAUML44EX4N001183 Mileage: 236030km/146662miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0050
Revision: 00000000 Serial number: AUX3Z0C2512094
Coding: 0007773
Shop #: WSC 98765 666 30770
VCID: 1F4D5514CEA6FDB
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0060
Coding: 0000002
Shop #: WSC 02353 785 00200
VCID: 24475AF8E7C0DE3
1 Fault Found:
17087 - Brake Switch (F)
P0703 - 000 - Electrical Malfunction - Intermittent
Freeze Frame:
RPM: 640 /min
RPM: 192 /min
RPM: 32 /min
(no units): 7.0
(no units): 34.0
Temperature: 70.0°C
T.B. Angle: 0.0°
Voltage: 13.92 V
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0420
Coding: 0007597
Shop #: WSC 03419 000 00000
VCID: 214953ECF8D2CBB
2 Faults Found:
00526 - Brake Light Switch-F
011 - Open Circuit - Intermittent
008 - Implausible Signal - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H02 0110
Revision: 01103502 Serial number: AUX3Z0C2512094
Coding: 0263168
Shop #: WSC 02313 785 00200
VCID: D8BFBE086B08CA3
Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00172 - Key 2 not learned
Freeze Frame:
Fault Status: 00101000
Fault Priority: 5
Fault Frequency: 0
Reset counter: 245
Mileage: 234864 km
Time Indication: 0
Date: 2012.02.26
Time: 17:04:28
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0050
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940576
VCID: 234559E4E2CED9B
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 729 B HW: 4E0 035 729
Component: Interfacebox H43 0150
Revision: 00000000 Serial number: 346D8037502020
Coding: 0000103
VCID: 275D4DF496F635B
Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 015 0240
Revision: 065A0000 Serial number: 898053000
Coding: 0037185
VCID: DABBA4001504D83
Part No: 4E0 910 772
Component: Sitzluefter FS H05 010
Component: Sitzluefter BFS H05 010
2 Faults Found:
00728 - Potentiometer in Positioning Motor for Left-Hand Central Vent (G136)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 234568 km
Time Indication: 0
Date: 2012.02.23
Time: 07:25:16
Freeze Frame:
Voltage: 13.40 V
(no units): 0.0
(no units): 0.0
00729 - Potentiometer in Positioning Motor for Right-Hand Central Vent (G137)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 242
Mileage: 234592 km
Time Indication: 0
Date: 2012.02.23
Time: 08:15:28
Freeze Frame:
Voltage: 13.70 V
(no units): 207.0
(no units): 255.0
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111003
Shop #: WSC 24103 444 84355
VCID: 2A5BB4C085E4083
Subsystem 1 - Part No: 4E1 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 24103
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 HW: 4E0 035 111
Component: CD-Changer H43 0220
Serial number: AUZ5ZBC1012376
Shop #: WSC 00000 000 00000
VCID: D6A3B030611CFC3
1 Fault Found:
00384 - Optical Databus
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 6
Reset counter: 7
Mileage: 233449 km
Time Indication: 0
Date: 2012.02.16
Time: 17:37:50
Freeze Frame:
Bin. Bits: 10
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 A
Component: Airbag 8.4E+ H08 0820
Coding: 0530707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H09 0030
Coding: 0012241
VCID: E5C187FC2C7A67B
Component: Lenkradmodul H02 0050
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H42 0060
Revision: D07 Serial number: AUDID3C2000250
Coding: 0000223
Shop #: WSC 03213 444 04780
VCID: DCB7A2181F30263
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H06 0020
Revision: 06 Serial number: 50003222012801
Coding: FCFE7BDD1B2304
VCID: 264340F091FC2C3
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 0
Reset counter: 245
Mileage: 234864 km
Time Indication: 0
Date: 2012.02.26
Time: 17:04:28
TO BE CONTINUED...
