Old 8th May 2012, 10:24 PM
GlynH GlynH is offline
Default Anpther bloody error that keeps recurring...
This one clears down but keeps recurring
Wonder which lambda this is?
Bank 1 I'm guessing but where is it located?
Address 01: Engine Labels: 07C-910-018-BHT1.lbl
Part No SW: 4E0 910 018 E HW: 4E0 906 018
Component: 6.0L W12/4V A ™0060
Revision: --H01--- Serial number: AUX3Z0E5368773
Coding: 0011773
Shop #: WSC 02313 785 00200
VCID: 214DAC0DF8D2F56
1 Fault Found:
19711 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
P3255 - 001 - Regulation at Upper Limit - MIL ON
Readiness: 0000 0000
Thanks & kind regards,
-=Glyn=-
Old 9th May 2012, 08:03 AM
B1- bank 1 = bank with cylinder 1 = right side of car as you sit in
S1 sensor 1= pre-cat sensor
Is W12 running on 2 ECU's? That might mean there are bank 1 and 2 for each ECU so you would need to know which ECU is error from. And on W12 sensors are probably hidden somewhere not easily accessible.
Old 9th May 2012, 10:32 AM
ADU UR quattro ADU UR quattro is offline
My advise is change both banks together, they both have lived there for the same time, just a matter of time before the other one goes.Thats my experience of it.
Old 9th May 2012, 12:47 PM
RanjS8 RanjS8 is offline
Default Pre cat o2 sensor
The sensor lives just after manifold in the down pipe...not sure about w12 however with the v8 on d2s it is normally difficult to see but if u follow the wiring down from the connector which is normally at the back of the engine bay you should be able to feel it...taking the down pipe off his a real pig...so find someone who can change it insitu....otherwise could become a pricey replacement....btw I know it is a w12 but is the fuel economy down is it running kinda rough???? Just curious to know he effect...
Old 9th May 2012, 12:50 PM
Theres 2 engine ECU's, 4 cats, and 8 lambdas on an a W12.....
Cats are a common failure and mega bux to fix.
Old 9th May 2012, 07:18 PM
Sorry my mistake, I assumed the car was a D2 S8.
Old 9th May 2012, 07:41 PM
you can change 2 lambdas that you can see if you look down the side of each bank, you will more than likely find that a bottle of cataclean will fix this and the light will turn itself off after around 150 miles or plenty of start stops after a long run to clear it out, bank one is driver side, they are not to bad to change and i found an ebay shop that dose parts cheap to, lambdas are about 80 quid each
also did the W12 that A8 parts have not get broken because of the lambda and cats failing ? and the lambdas are on ebay for sale ?
