Old 17th June 2012, 02:58 PM
A8_Tony's Avatar
A8_Tony A8_Tony is offline
Default Towing mode
Well guys, following on from the battery issue I had, it now seems the car thinks I've got a permanently attached trailer/caravan!
This means the car is currently sat in towing mode, without the ability to turn it off in the mmi
Anyone else experienced this?
A8OC Founder
The A8 Owners Club here
Old 17th June 2012, 03:21 PM
Does your car have towbar fitted? Could be a short there.
Old 17th June 2012, 03:22 PM
47p2's Avatar
47p2 47p2 is offline
Does it have the socket for a towbar electrics fitted?
If so it could be water that is causing a short
Edit
You just beat me there Richard....
Nite Blue 3.0L SE Quattro
Old 17th June 2012, 06:04 PM
A8_Tony's Avatar
It does have a detachable towbar. I pulled the socket down today, we've had a lot of water with the rain here, but couldn't spot any signs of ingression. I guess I'll have to get a hair dryer on it or something.
Does anyone know what fuse controls the electrics going to the socket? If I can pull that, I can then quickly identify if that's the issue
A8OC Founder
Old 17th June 2012, 07:14 PM
47p2's Avatar
Spray plenty WD40 into it and it should help
Old 20th June 2012, 10:45 PM
A8_Tony's Avatar
A big thanks to PsYcHe who yesterday coded out the towing control ECU for me, and adjusted the parking sensor, and self levelling system to think it hasn't got a towing control unit.
The car is now back on track, but I obviously have an issue with the towing control ECU on the car, but have no idea where it is!!!!
Anyone got a clue?
A8OC Founder
Old 21st June 2012, 04:49 AM
Godders Godders is offline
Anyone got a clue?
You'll find it lurking underneath the battery - remove the battery and you'll see a couple of Torx screws holding a black box to the panel underneath. It will be printed with Westfalia logos.
2003 D3 A8 4.2 Atlas Grey -
Factory: Adaptive lights with coming home function, 19" wheels, Solar Sunroof, Bose, Nav, TV, Paddle shift sports wheel, sports suspension, sports seats, rear seats with electric lumbar adjustment, heated seats and climate all round, ski hatch, int light pack, auto dip/fold mirrors, voice command, cordless phone, wooden gear knob, towbar, power boot lid
After: LPG, AMI with HDD
Pending: DVB-T Tuner & fixing niggles
Old 21st June 2012, 02:43 PM
Here is the retrofit instructions from Westfalia, who are the OEM for the towing system..... hope it helps
http://www.westfalia-automotive.de/f...7391101-02.pdf
Old 21st June 2012, 03:15 PM
Under the battery... Hmm... Wonder if it's just a loose connection under there.
Old 21st June 2012, 03:58 PM
or water, that's where I was getting water ingress from one of the drains - a fat blue pipe just in front of the battery compartment going to the wheel arch...
