Old 6th October 2012, 06:14 PM
Godders Godders is offline
Default Air Compressor Fix
After much research into the error I found on the father in laws A8
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
and running VAGCOM whilst he was driving I managed to establish the compressor was struggling to run to the max pressure of around 15 bar.
The max pressure it could muster was 9 bar and it wouldn't hold that. Also there was a rattle from the front nearside that we couldn't trace despite replacing a number of suspension arms (its now quiet and we think the system wasn't pressurising sufficiently and it was the strut)
As most of you know the only alternative is to replace the compressor with a £1k replacement from Audi. I was trying to find spares for the WABCO compressor and stumbled on the following site.
http://www.vwaudiforum.co.uk/forum/s...rip-amp-repair
This chap is manufacturing a replacement compression ring for the piston for the All-road but states it should fit the A8. Well I followed the link to his eBay shop and took the plunge.
Arrived in 3 days, managed to fit today in just 2 hours and the system now runs up to 15 bar and no more sensor error. He supplies the ring, a seal, cable ties and replacement set screws.
Just a note I have no affiliation with this fella but I'm happy spending around £35 as opposed to £1k.
I haven't done a write up (yet) but if anybody needs advice drop me a PM
2003 D3 A8 4.2 Atlas Grey -
Factory: Adaptive lights with coming home function, 19" wheels, Solar Sunroof, Bose, Nav, TV, Paddle shift sports wheel, sports suspension, sports seats, rear seats with electric lumbar adjustment, heated seats and climate all round, ski hatch, int light pack, auto dip/fold mirrors, voice command, cordless phone, wooden gear knob, towbar, power boot lid
After: LPG, AMI with HDD
Pending: DVB-T Tuner & fixing niggles
Old 6th October 2012, 07:05 PM
Write up... Definitely
Glad to know it.. as I think there will be a few D3s that will be needing it soon
Old 6th October 2012, 07:07 PM
Mutley Mutley is offline
Yeah, mine being one of them lol, however I didn't know it should be pushing at 15psi so I guess that's my next test o see if mine actually generates 15 when on ?
2003 Audi A8 D3 4E, 102K Miles, 20" Alloys, 4.2 Quattro
Fixes i've resolved myself and with the help of the forum and Vagcom
  • Update MMI to 5570
    Hidden Menu
    Brake Switch Repair and ESP Light
    Reset Parking Brake Calibration
    Removed Speed Limiter
    TV In Motion
    Reset and resolved issue with Cruise Control
    Coming Home Lights
    Lowered 10mm
    MMI Replacement brass gear for silky smooth action
Old 6th October 2012, 07:18 PM
Not 15psi, it is 15 bar which is around 220psi !
Old 6th October 2012, 07:21 PM
the link for the ebay repair kit is
D3 Air Suspension Compressor repair kit
and the PDF for the original repair is now attached here too
File Type: pdf C5 Allroad Suspension compressor repair.pdf (988.8 KB, 2167 views)
Old 6th October 2012, 07:36 PM
47p2's Avatar
47p2 47p2 is offline
Interesting read, thanks for posting
Nite Blue 3.0L SE Quattro
