Old 10th October 2012, 11:06 PM
maglite's Avatar
maglite maglite is offline
Default Quick 10 minute Vanity mirror LED upgrade mod
Hi, I did a quick mod today. swapped the traditional filament type festoon bulbs in the vanity mirror light clusters for some LED ones (did a quick guide too for anyone that's interested).
Before:
After:
Audi A8 D3 3.0 TDi
Peugeot 406 2.0 HDi Executive
Old 11th October 2012, 07:51 AM
It's worth pointing out, for those that don't know, that LED bulbs are polarity-sensitive so test before reassembly (and turn them round if they don't work at first).
Also, the newer SMD types have larger emitters (the yellow areas) and some can be very bright - if you want that.
(The PF D2 setup is slightly different as the bulbs are actually in the sunvisor - 2 each side.)
Old 11th October 2012, 08:28 AM
(The D2 setup is slightly different as the bulbs are actually in the sunvisor - 2 each side.)
Guess that must be in the PF HP? mine are in the headlining behind the visor
Old 11th October 2012, 09:51 AM
Good write up, swing around in the A8 sometime.
Old 14th November 2012, 07:42 AM
Conquistador's Avatar
Had a go at this earlier, I managed to remove the lens rather than the actual light assembly because that wasn't budging one bit, and now can't seem to click the lens back in
So now I'm left with an ugly gaping hole above my head, and a plastic lens doing nothing, as you can see...
Any ideas maglite?
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 14th November 2012, 08:45 AM
I did mine yesterday with some warm white SMD festoons I had in a drawer that were too bright for the number plates.
I had a lot of trouble removing the lamps from the headlining as nothing would engage with the metal tab-spring, and the tab-spring bent out.
I removed and reshaped it, but now I can't get the lamps to be a tight fit in the roof, they are loose and rattly. It is as though the spring is too short now.
Google gives examples of others saying this across all models. Any tips for rectification?
New ones are £8 ish,
Might have to make a new spring out of plastic or something or just dab some hot melt glue on it.
http://www.ebay.co.uk/itm/370443700311
Old 15th November 2012, 04:34 PM
maglite's Avatar
Uh oh.. Ok what has happened here is that you have managed to pull off just the lens rather than the whole light assembly. I used an old plastic SIM card surround, that I cut in half (like a credit card) to prise out the light fixture.
I think the best thing now to get the lens back on, would be to take out the light fixture and then superglue the lens back on to it before putting the whole thing back in the car.
Audi A8 D3 3.0 TDi
Old 16th January 2013, 08:36 PM
For future reference, the D4 ones are LED and fit the D3 roof lining but the quality of the LEDs is a bit ricey/blue like LEDs form 5 years ago.
4H0947105A
http://www.ebay.de/itm/280994398525
