Old 29th October 2012, 02:05 PM
Lightbulb W12 plug change guide/ walk through
after seeing David had done a service i decided to do the same and make a little guide. i know there are very few W12 D3's on the forum but hear it is any way
12 Plugs were not cheap around £210 for a full set
I did mine one side at a time. first thing to do is take off the maf and the connection pipe
do this on both sides
Remove the Two T30 Torx head bolts and the half will split, the hoses are just slipped on and easy to remove
http://i866.photobucket.com/albums/a...025_115250.jpg
i found a broken pipe so i fixed that while i was there
you can see where the oil from the breather was leaking a tad so i cleaned that up too
On to coil removal
They are simple to take out only pushed in place they are new as they were done under a recall just before the new engine was fitted
Repeat for all the plugs
Hear you can see the 2011 Stamped engine
The repared pipe back in place
Reverse to put it back together
And now for the other side
Same as the other side only this time you will have to remove the oil filler spout to be able to remove the number 7 coil pack
one 10MM bolt as you can see
You can see the different angles that form the W between pistons
Again reverse the steps to re assemble
Its quite easy and may save you quite a fair amount of money to do it yourself audi would charge £500+ for this simple process
I will do some more when i get a chance maybe the full oil change and air filters.
Old 29th October 2012, 02:15 PM
Good guide, £210 for a set of plugs! I think I paid £90ish for my set of genuine Audi RS 2 plugs (which is what I use in my RS 6) and I thought that was pricey. What NM did you tighten the plugs to?
Old 29th October 2012, 02:24 PM
Sorry to bring bad news but you need to do more shopping around. There is set of 12 genuine Audi PZFR6J-11 for £50 on e-bay. NGK PZFR6J-11 are about £8 a piece in retail and £13 from dealers. Looks like you found the most expensive place to buy them.
Old 29th October 2012, 03:46 PM
mmm bugger i thought they were very expensive but did not want to cut corners when its so involved in taking off the intake ect to change them.
oh 22ftlb or 30 nm on the torque wrench
Old 2nd April 2016, 05:47 PM
Leveret Leveret is offline
I've just come across this plug change guide and wanted to thank daviesbike for such clear information. I've googled W12 plug changes often and never seen this - best info yet for when I eventually attempt it on my nearly 60,000m SWB W12 - it''ll be due at around 70k. Well done - even the torque values! Don't suppose you remember how the old ones looked compared with the new? It's such a big job one is tempted to leave it a bit longer than the manfacturers spec!
