Old 2nd January 2013, 02:08 PM
tadej's Avatar
tadej tadej is offline
Default Change headlight from FL to PF
Hello!
I have one question for you guys. I have a xenon plus (bixenon) headlights from S8 '02 FL and now I want change this lamp to my A8 '98 PF. Is this possible or not.
First difference is PF headlights have a 5 pin connector, FL headlights have a 10 pin connector.
Regards, Tadej
A day you didn't learn something new is a wasted day :!:
Old 2nd January 2013, 08:20 PM
You would need to change all the panels on the front end to make that look good as the indicator is part of the assembly in the FL, and it's a different height, so bonnet, wings, bumper need swapped.
Old 14th January 2013, 08:54 AM
tadej's Avatar
Thanks for all info
Regards, tadej
Old 14th January 2013, 05:05 PM
probably easier to do a xenon conversion using a kit if you want to do that at all
