Old 22nd March 2013, 08:55 AM
Curtis's Avatar
Curtis Curtis is offline
Default getting radio working
so when my car was stolen last year the clowns took the bose amp and cd shuttle along with some other stuff. after getting the car to a standard i am happy with that i can drive it i am now getting bored with not having a radio and everytime i drive the car i try to turn the radio on that does not work.
i still need to source a bose amp and new wiring loom but i am thinking i should upgrade the whole audio system. i would like to get it that i can play mp3's or have some sort of memory card or usb system.navigation and tv will be awesome to have.i dont want to spend to much as i rather use that money on the mechanical things the car needs for now.so would like to know if anyone can help with any info on setups i could go for.would like to keep it standard.
is it possible for me to get the replacement amp and wiring loom and if i upgrade to navigation and tv later will it still be usefull ?
i have the pf single din radio with volume nob on left side if it helps.
here is a pic of what happens when you have the intelligence of a buffoon and cut the wiring harness instead of unpluging it and prying the glovebox open when its unlocked when you can just press the button to open.
ID:	5776   Click image for larger version
Old 22nd March 2013, 10:05 AM
RanjS8 RanjS8 is offline
Default Bose amp
I know someone with a Bose amp so if interested I can pm you his number. You might want to discuss getting bits of the wiring loom but that might be tricky to source complete.(probably ask the forum sponsor)
I would keep the standard system and get a phatbox in place of the cd changer....this will play mp3s happily.
The radio antenna isn't to hard to sort out....recently did this and I got the necessary cable and adapters from maplins....
I wouldn't try going down the tv route as you will need a double din fascia, which for a PF is virtually impossible to source.
Ranj
Old 22nd March 2013, 10:24 AM
Curtis's Avatar
i want to see if i can source one in south africa before i have to bring it in. it just makes things easier. but if i dont come right i will pm u for the number.thanks
what is a phatbox?
i did come across this website
http://www.stopshop.co.za/buy-audi-a...oth-radio.html
not sure if its good idea to go that route and try make it fit in the dash with a fl double din.
Old 22nd March 2013, 10:52 AM
Default Fl double din
If you don't mind the extra work then fl double din that it probably better way to go....the only issue you will have is that the heated seat switches are built in to the climate control module on the fl cars....
I haven't used a phatbox myself, however I have seen people refer to it and it seems to be a big hard drive to hold mp3s, which integrates with the existing system. Google it....
Old 23rd March 2013, 05:33 PM
There's one for sale on AudiSRS:
http://audisrs.com/about44542.html
Old 28th March 2013, 09:38 AM
Curtis's Avatar
Thanks, but it looks like its sold.
