Old 23rd May 2013, 01:45 PM
nkotecha nkotecha is offline
Default Mmi fw 5570
Folks - As you may be able to tell from the INTRODUCTIONS Section, I have returned back to the BRAND.
I am after some assistance and that was in the form of upgrading my MMI on my S8 to 5570 - I thought i could just buy the FW CD/DVD but that does not seem the case - will stand corrected.
Does anyone have a BACKUP :copy that i can borrow?
Also any thoughts where i can get a 2013 DVD apart from the STEALERS!!!
Nik
Old 23rd May 2013, 02:12 PM
I can sort you a map DVD assuming its 2g which it should be if you have a nav drive - pm me if interested
Firmware updates can be found online but hopefully someone local to you will have them
Old 23rd May 2013, 04:20 PM
Which wheel do you have on your MMI.. if it's flat, then it's 2G and can be upgraded to 5570 and you can obtain the maps from *cough* the internet *cough*. If there's a little joystick on top, then you're on 3G and that's a different system.
Old 23rd May 2013, 04:29 PM
Assuming you are 2G - jst google this string...
B508BCC64447828E7E8698D255E97C04E700AEAA
and this string..
Audi_MMI_5570_3cd_set_4L0.998.961_
Old 23rd May 2013, 05:41 PM
OK - so I have downloaded the Backup Copies - Inserted DISC 1 5570 Update - Through Service Menu and It upgraded - I get the 55.70 Version on the SW - BUT - it did not ask for the other 2 CD's
Is this normal?
I also then went back with VCDS and enabled Battery Meter and Oil Level - ALL OK?
Question - How do i enable the 3D Maps view - cannot find it anywhere - sorry am i trying to be techie when i am clearly an amateur?
TIA
Old 23rd May 2013, 06:49 PM
You have to start over with disk 2 & 3, they are not asked for automatically.
It is possible you don't have any units that need them though.
When in NAV, I think you press SETUP and it is in one of the menu options.
It is good, but you lose streetname labels on the maps.
Old 23rd May 2013, 08:42 PM
OK so all done - the S8 is now running 5570 and 2013 Nav - Thanks for all help on the Thread
Now onto the next item.....Ummmm what can i find?
Old 23rd May 2013, 09:34 PM
Upgraded exhausts
Old 24th May 2013, 08:21 AM
Now that sounds like a plan - Milltek? - or should i try something else -
Old 24th May 2013, 09:11 AM
Milltek seems the best option.. But you could always look at a custom, maybe speak to Unit20 and see what they recommend.
