Old 2nd September 2013, 08:02 PM
Conquistador's Avatar
Unhappy "Device fault" message on MMI for CD changer
While changing from one CD to another, I suddenly got the message "Device fault" on my MMI screen. Tried the 'Tel' + 'MMI select Button + 'top right button' to reset the whole MMI but still not working and it's now completely dead all other MMI functions work
Anybody else had this before? I listen to CDs almost all the time and I'm always changing between CDs so it does get a lot of use.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 2nd September 2013, 09:11 PM
Does sound like the CD changer may have died.. Could have just jammed on a disc.. Sounds like the ideal time to upgrade to an AMI
Old 2nd September 2013, 09:52 PM
Not sure about the AMI upgrade. All I want is a simple CD change in working order lol. Around £100 on ebay for a replacement by the looks of it...
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 2nd September 2013, 10:46 PM
the component protection will kick in as well if you change these units so factor in a trip to the dealers
or before writing it off, try to fix the one you have,
try this
power off, keys out, mmi off
remove the unit from the media position with the audi unlocking key thingy
carefully detach the most cable at the rear,
leave of for 5 mins or so, then reattach the cables
power up and give it a try, shouldnt need to reboot the mmi
Old 7th September 2013, 11:03 AM
Ah yes, didn't think of the theft protection. I assume the 'Audi keys' are two prongs which remove the unit? Like what are used on the head unit of other cars?
I definitely don't have any of those
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 7th September 2013, 05:02 PM
its more key looking than the 2 prongs
http://www.ebay.co.uk/sch/i.html?_od...moval&_sacat=0
not sure if there are different versions
Old 12th September 2013, 05:51 PM
Well the keys came. I removed the unit and unplugged it for a few minutes.
When I put everything back, the unit started flashing, as such:
View My Video
...and hasn't stopped since. I left the glovebox open, locked the car, came back 15 minutes later and looked through the window and its still flashing away with the same pattern!
When I go on CD in the MMI, all CD slots now show as Empty rather than 'Device fault' like before. Looks like I'll need a new unit
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 12th September 2013, 06:29 PM
thats not a good sign, I do have one i would let go for a £100, and whatever postage costs, it worked perfectly, just removed it to put the AMI in.
Old 12th September 2013, 10:30 PM
Pop the case off it and check for any jams inside.. Otherwise it's gubbed and you're looking at a replacement (see above), or an AMI.
Old 10th October 2013, 07:54 AM
have you still not get any cp kicking in when you put the new one in?
