Old 4th November 2013, 06:59 AM
Somerandomguy's Avatar
Default Blank DIS
After sitting on the drive for a week, all of a sudden my DIS is blank. It took a few miles to notice it as the car starts and runs properly, just nothing on display, nor does the time and date change, despite updating it in the MMI.
I have checked the fuses, and nothing blown, so have run a VCDS scan. There were loads of all sorts of errors so have cleared these to reveal a couple of persistent ones as follows:
Control Module Part Number: 4E0 910 401 J HW: 4E0 907 401 B
Component and/or Version: 3.0L V6TDI G000AG 0020
Software Coding: 0011773
Work Shop Code: WSC 00720 210 86407
VCID: 224FEEBB860F
1 Fault Found:
18276 - Transmission Mount Valve 1 (N262): Short to Plus
P1868 - 001 - Upper Limit Exceeded
Freeze Frame:
RPM: 0 /min
Torque: 265.2 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.02 V
Bin. Bits: 00101100
Torque: 89.7 Nm
Temperature: 8.1°C
Readiness: 0 0 1 1 1
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Control Module Part Number: 4E0 910 769 Q HW: 4E0 035 729 A
Component and/or Version: Interfacebox H43 5570
Software Coding: 0000002
Work Shop Code: WSC 00000 785 00200
Additional Info: 4E0910609A Bedienteil MMI H42 0020
Additional Info: Geraet 00200
VCID: 3A7F36DB0E9F
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 205
Mileage: 239360 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:55
Freeze Frame:
Bin. Bits: 10
Address 34: Level Control Labels: 4E0-910-553.lbl
Control Module Part Number: 4E0 910 553 F HW: 4E0 907 553 E
Component and/or Version: LUFTFDR.-CDC H05 6260
Software Coding: 0015520
Work Shop Code: WSC 02313 785 00200
VCID: 2647F2ABEA27
1 Fault Found:
00456 - Control Module for Access and Start Control (J518)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 240
Mileage: 0 km
Time Indication: 0
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Control Module Part Number: 4E0 910 289 A HW: 4E0 907 289
Component and/or Version: Komfortgeraet H04 0040
Software Coding: 0001755
Additional Info: 4E0907719 Neigungssensor H03 0020
VCID: 2759FFAFED2D
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 205
Mileage: 227514 km
Time Indication: 0
Date: 2013.05.11
Time: 13:04:34
VCID: 224FEEBB860F
2 Faults Found:
Freeze Frame:
RPM: 0 /min
Torque: 265.2 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.02 V
Bin. Bits: 00101100
Torque: 89.7 Nm
Temperature: 8.1°C
17059 - Cylinder 5 Glow Plug Circuit (Q14): Electrical Fault
P0675 - 001 - Upper Limit Exceeded
Freeze Frame:
RPM: 903 /min
Torque: 109.2 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 12.31 V
Duty Cycle: 24.5 %
Temperature: 7.2°C
Bin. Bits: 10110000
I have taken the cluster out just to make sure there are no loose cables, and will do the same with the alarm module and MMI control as these are showing faults, albeit the alarm is an old one.
Other than this, does anyone have any suggestions?
Thanks very much
2004 A8 3.0 TDI Sport Brilliant Black
Came with: Black Valcona/Alcantara Leather, KESSY, rear blind, flappy paddle gear change, Phone Prep, TV
Added:Bluetooth, AMI, Hybrid TV, Parking plus, Ski hatch, towbar, DAB, Umbrella Holder, Reversing camera, Auto lights, Wheel refurb
Things to fix: Turbo fault, power drain
Old 4th November 2013, 07:20 AM
I'm presuming you haven't just hit the button underneath the right hand stalk that cycles the DIS functions at all? It's easy to hit it with your hand and not everyone even knows it's there on an Audi . . . One of the options when it cycles is to turn the DIS off
Old 4th November 2013, 07:29 AM
Default If only...
Indeed I have tried pressing that little button with no improvement. The display is completely blank, no radio info or even gear indicator.
Thanks again
Old 4th November 2013, 07:56 AM
HPsauce HPsauce is online now
Is it cold? Mine goes blank in cold weather. It's 4C outside right now and mine shows nothing.
It will be OK when it warms up.
Old 4th November 2013, 09:16 AM
It is a little cold, I have kept the cluster inside over night so will see if a warm cluster works any better.
Do you get any VCDS errors when your cluster is blank?
Old 4th November 2013, 09:32 AM
No, it's just the LCD material doesn't work properly until it's warmer.
Old 30th January 2014, 06:14 AM
Default Follow up
For the sake of completeness, I have now resolved this by replacing the cluster.
I managed to source a cluster from ebay with the same part number and swapped over the major components to diagnose that the main circuit board was kaput. Swapping this over left the cluster in component protection- not a nice thing to see, no interior lights on any panel, only the speedo dial working (a bit pointless at night as I couldn't see it anyway due to the lack of lights) and several warning light lit.
A visit to the dealers with the old and new clusters and 1.5 hours later i have a fully working cluster with the correct mileage, yay
Old 30th January 2014, 06:51 AM
mannyo mannyo is offline
Good to hear its sorted, and that its possible for a donor cluster to display the correct mileage. At least cluster swapping on the D3 is easier than the D2 it seems.
Manny
Past
Old 30th January 2014, 08:43 AM
Interesting as the clusters are not mileage correctable by the dealer unless it's up the way iirc, good that you got it sorted though.
Old 1st February 2014, 10:10 AM
Yes, the milage did go up by about 30k, I'm glad its fixed too, but the problem is that its now able to show errors again.....
Tags
dis
