Old 5th February 2014, 11:31 AM
3.7 slp 3.7 slp is offline
Default Help removing central wood trim
would anyone have a photo guide to removing the wooden trim as have to replace the hazard relay swich. Is it just a caes of pulling from the bottom to relase the holding the clips....dont what mess up as have not had to do this as yet.I have a new hazard swich on its way as i type..think that his been giving my alarm indcator flashing probs over the past few day.
Thanks eveyone.
Old 5th February 2014, 12:11 PM
These should help Steve
http://www.audipages.com/Tech_Articl...im_removal.pdf
http://ocarbon.com/blog/2011/02/d2-a...removal-guide/
Old 5th February 2014, 01:05 PM
Great thanks very much
Neil hope that you are doing well sir
Old 5th February 2014, 02:08 PM
This is such an easy job that even I managed it!
But the panel never fitted right and I discovered that was because one of the fittings was missing. Quick call to A8 Parts and I was sorted - the panel now fits flush.
Old 5th February 2014, 02:49 PM
Thanks all got the panel off fine. but that hazard switch is a night mare to get out gave it a go at lunch time in the work car park..as it was rainning and could not go for a walk...no luck as yet getting the switch out ...will try later im trying not to be too heavy handed..
...Any tips on getting that cheeky switch out would be a great help
Old 7th February 2014, 10:36 AM
Many thanks panel off and new hazard switch relay replaced now i have hazard flash and get both indecators flashing when arming and de arming the alarm.. Had to give the plug into the back of the relay on heck of a pull...quit the workout
Old 7th February 2014, 12:30 PM
glad you got it sorted Steve!
