Old 27th March 2014, 09:49 PM
Palmer Palmer is offline
Default Condensation in rear lights
Yo guys
got some condensation particularly on the offside rear light cluster, the one in the wing not the boot.
advisable to take out clean and reseal or just, buy a new one?
Chris
Old 27th March 2014, 11:47 PM
If you have the old style lights then take them apart and dry them out, the pcb's come off the back giving easy access to dry them out, if you leave it too long you will get corrosion on the pcb which is not good.
Old 28th March 2014, 06:38 AM
Message to the mods - Thread needs to be moved, I think!
Old 28th March 2014, 07:31 AM
Ahhh ****e i posted in D2! LOL
Old 28th March 2014, 10:49 AM
It was the mention of PCBs that alerted me to this! Just old fashioned bulbs and wires on the D2s!
Old 28th March 2014, 01:04 PM
mannyo mannyo is offline
I have a small amount in one of my rear lights, but only the reversing section. The LED area is perfectly fine and dry.
Manny
Past
Old 28th March 2014, 01:23 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
I got exactly the same thing with mine.
need to strip them out and take a look and see bout resealing.
[center]
06 3.0TDI Quattro:
Options:
Old 29th March 2014, 07:05 PM
Happening in both wind lights and the reverse lights in the boot too.
How would one go about resealing them? Or rather what would you use. Had a look today and they look like the come out fairly easy....
Old 30th March 2014, 07:14 PM
My wing-ones had this. You can take them out by removing the 10mm? nuts behind plastic caps. These are located beside the lamp when the boot is open. There are cut-outs with caps in the plastic boot aperture trim.
Be careful not to drop the nuts as they will fall into the bodywork.
A magnetic pickup tool is good for the last few threads.
You can then remove the lamps , remove covers and dry them in a warm place or maybe top oven while the bottom oven is on minimum.
Clean the seal of the covers and mating surface. Apply a tiny smear silicone oil if you like. I put silica gel packs in mine, you can get these from camera shops or ebay.
A year ow two later, the boot lid ones are the same but a lot more involved in removing them.
Old 31st March 2014, 10:15 PM
Gonna get mine done this week, whats best to seal it with? Never heard of silicone oil lol
