Old 18th May 2009, 01:09 AM
pdxaudi
Guest
Posts: n/a
Default Possible Engine Swap?
Ok so I may have to replace my head gaskets - if so its going to cost a lot of $$$....so my thought is maybe picking up an S8 or S4 engine and doing a swap! What would be the difficulty in doing a project like this? Obviously a new engine would require it come with the ECU and wiring - other than that are there any other "problems" I may run into??
Old 18th May 2009, 05:49 AM
Will,
See my engine swap thread here and here. As long as you get the ECU it should be a straight swap. You'll also have an extra 40 horses with the final drive ratio of an A8! Bargin!
Old 18th May 2009, 08:33 AM
The 340Bhp engine swop itself wont yeild a great deal of benfit, sub 10% power increase, but combined with a gearbox change and rear diff swop, then the S8 final drive ratios will certainly make it all a lot more nippy
I dont forsee any major problems up front... You can keep your A8 instrument cluster I should imagine, it should work fine, although you'll keep red-lining as the S8 combo will go round to 7000 where your A8 redline starts at 6250
One possible hurdle though is some boring red tape - We've come up against issues in the past trying to get an S8 AHC engine into the USA as we dont beleive the AHC was ever cleared for emisions etc to be run in the USA, ie you guys never actually got the S8 with the AHC over there.
There is some concern that if you tried to import an unapproved engine, that it may not get in - Not sure how true it is, but its worth a bit of homework first.
Theoretically, we could break the AHC down for parts and ship the cams etc seperately, but its a lot of work this end, and loads of work for you to put it all back together again....
We know that an S8 will run an A8 gearbox without problems as long as you change the rear diff, so I think this is quite do-able....
... not to mention quite interesting
