Old 20th August 2014, 08:09 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default Chrome headlight Switch
I've made several of these up for the A3 boys and thought it was time to do one for my self.
Here it is.
A3 8P chrome switch fitted to the A8 unit.
ID:	8778   Click image for larger version
ID:	8779   Click image for larger version
[center]
06 3.0TDI Quattro:
Options:
Old 20th August 2014, 08:22 PM
WHAT ??????
That is fantastic, what a great little mode. The style of chroming matches the one on the seats buttons.
I'll have one to.
So all you need is to buy a A3 8P light switch, unplug mine and plug new one, job done??
Cheers Scott
PS. Title says Window switch not Lights switch
Old 20th August 2014, 08:27 PM
ScottD3's Avatar
Edited it. Not sure where that title came from lol
Not exactly.
You need to strip down both switch units and swap the knob over.
It's fiddly but easy enough.
I'm happy to do one for anyone.
[center]
06 3.0TDI Quattro:
Options:
Old 20th August 2014, 08:28 PM
Have you got spare chrome knobs???
Old 20th August 2014, 08:39 PM
Well, never mind, went on eBay to see if there are any and there was one on auction ending in 33seconds with current bid £3.78 and £9.50 postage.
In panic I placed the 20quid bid and won the thing for £5.50 plus £9.50 postage, £15 in total for this mod is just amazing as next the cheapest one costs £40 up to £60.
Scott, great stuff once again.
Guy lives in London and ships 1st class so I will keep my fingers crossed for it to arrive before weekend, it will look great with freshly deep cleaned interior.
PS. This is it isn't it????
http://www.ebay.co.uk/itm/AUDI-A3-8P...torefresh=true
Old 20th August 2014, 08:47 PM
ScottD3's Avatar
That's the unit buddy.
The prices very so much mainly due to it's options but as long as it's with in your budget and has the chrome knob you're laughing.
[center]
06 3.0TDI Quattro:
Options:
Old 20th August 2014, 09:02 PM
So it's the correct one then, smashing.
I was prepared to pay £40 if my bid of £30 in total was too low, but I end up winning it for £15, I am laughing now.
When is fitted I will just throw a smile and get out from the car all proud
Cheers Scott
Can't wait for it !!!!
Old 21st August 2014, 07:14 AM
ScottD3's Avatar
Not a problem mate.
I assume you're more than capable to do it but if you get stuck or anything just let me know and I'll help you out the best I can.
[center]
06 3.0TDI Quattro:
Options:
Old 23rd August 2014, 12:05 AM
Hi Scott.
I do need help. I thought I will do that in no time, but after two attempts so far no success. Both moments were not the best ones to do it, but.....
I've got both switches in pieces,I just can't get both knobs out of the body.
I've tried all the positions with both ball pins pushed in and nothing.
Please help
Old 23rd August 2014, 05:56 AM
ScottD3's Avatar
I'll do my best explaining this but if it don't work you're more than welcome to phone me.
Both light switches are same internally.
Remove the backing an circuit board.
You're left with the whit middle, two prongs with springs and the black guide inserts for the centre.
Remove the springs and prongs so you don't lose them.
On the old switch, prise out the two rubber/plastic guides. These don't help in releasing the plastic but gives you more room.
You can't get the switch knob out or the centre bit. They are keeping each other in.
You can't really see the 2 little clips that keeps the knob in but they are there below the two arms with the balls in the end.
You need go get a thin screwdriver under the arm. That's where the clip is. There is a slight gap between the clip and main body of the white unit.
This won't effect the switch knob if you damage or snap the arms off on the old switch but try not to snap them off on the A8 one cause the knob will fall off.
There's two you need to bend out and the knob will fall out.
Not sure that helps but that's it.
[center]
06 3.0TDI Quattro:
Options:
