Old 26th May 2009, 01:58 PM
Waynester2 Waynester2 is offline
Default Slippy transmission again
Hi Guys,
My slippy transmission problem is back again, its was intermittent but now seems to be around all the time and at 144444 miles, I am getting concerned about failure!
Basically transmission has never been that smooth, usually a bit of a jerk on gear changes, occasionaily the only way you know its changed gear is by the rev counter, which I guess is normal for the rest of you!
In addition when driving it along, it will sometimes over rev, during light acceleration a bit like slipping the clutch then lock up (I'm assuming this is the torque convertor) and carry on as normal. If you use TIP and force it to stay in say 4th doing say 60mph then give it light acceleration it will speed up, but when you take your foot off, you get a little over rev and a small increase forward, then back to normal.
I have just been googling and some have said the Air Mass sensor maybe to blame, and cleaning it might fix it, anyone tried this? Is it easy to do? I guess its somewhere in the air intake hose.
If you drive it hard, in auto or TIP it behaves itself perfectly, no slip, and loads of power, (its fairly rare I drive like this- nice to know its there though)
On top of this, I have noticed the whine which has always been there in reverse, is now there was well in D as well, but not there at all in Neutral.
Anyone got any ideas? I know the whine can be an ATF issue, I did have it changed end of last year, this then caused a leak (you could smell it dripping onto the exhaust) and I took it to a transmission specialist who fixed the leak and then topped up the ATF and said he thought the box was fine.
Any thoughts / experiences welcome, I am about to spend a load of money on tidying up the bodywork, so would be interested to hear your opinions!
Wayne
8 - 4.2 - 2002 - LWB
4 - 2.5 - 2004 - CVT - B6
Old 19th October 2009, 03:48 AM
A8quattro
Guest
Posts: n/a
Default Mine too
I have similar symptoms on my A8. After replacing the spark plugs, the problem mostly went away. See, I had engine misfires fault codes & that evidently confused the transmission. With the misfire codes no longer happening, there is still, on occasion, the issues you are describing without predictability. I was concerned I wouldn't be able to accelerate when needed, but as you described, all the power I need is there when I need it most.
Based on the issues I had with the misfires, does anyone know if the coils and/or spark plug connectors need to be replaced at a certain interval? Again, no more misfire codes, but does that mean the coils and/or connectors are still working in tip top order?
Old 22nd October 2009, 01:06 PM
I've come to the conclusion now that its meant to do it, been doing it for over 12k now, (as long as I have owned it) I think the mid gear lockup is meant to be there, you get the feeling you've got 6 gears, but thats about it. Shes just had a 10k service and I asked the mechanic to take her out for a test drive to test the MAF and he says its fine, and doesn't know what I'm complaining about. Others have said the 5spd auto on audis arn't that smooth compared to bmw and merc's anyway....
I also have the VAGCOM print out and its clean other than the usual, alarm went off, tire pressure monitor switched off etc.
W
Old 31st October 2009, 05:29 AM
A8quattro
Guest
Posts: n/a
Default Try a fuel injector cleaner
Chevron Pro-gard, or something similar that is high quality. Seems to have helped mine; misfires are gone, so no issues to transfer to the transmission.
