Go Back   A8 Parts Forum > A8 D4 > D4 - Everything Else
D4 - Everything Else Holding forum for all D4 banter until membership grows and we'll expand out
Old 24th April 2015, 12:31 PM
nath nath is offline
Default audi s8 part number
does anyone have access to parts numbers please
id like to check to see if the a8 and s8 rear anti roll bars are differant
many thanks
nath
Old 24th April 2015, 12:49 PM
It would help if you gave the year but generally sport models have the same bigger diameter antirollbars as S8 and non sport models have smaller diameter ARBs. You will also find that most of the time it will be specified linked to build code rather than A/S model.
Old 24th April 2015, 05:02 PM
the car is a 2010 4.2 tdi
there is no listing for a sport model on the d4 chassis
it is either an se or se executive
Old 24th April 2015, 05:43 PM
Default Too many to chose from
It looks like the different cars have different ones up front while the rear is pretty standard unless you have specced it for rough roads but i would not think so.
Check your PR numbers to see what you got.
If you want stiffer the armoured versions are bigger / stiffer
Old 24th April 2015, 06:44 PM
cheers del
found the pr code 1 bk on my service book sticker
just wondered if i could swap it out for a thicker rear anti roll bar to
help improve the front grip in the corners
Old 24th April 2015, 09:10 PM
Old 24th April 2015, 11:33 PM
here is the link to the 2010 price and specification list
https://www.audi.co.uk/content/dam/a...20Jan%2010.pdf
as you will see there is no sport vehicle listed
simply
se
se executive
obviously been one released since
Old 25th April 2015, 05:10 AM
simply
se
se executive
That's correct there was only 2 specs available on release
