-   -   MMI and Nav updates (https://forum.a8parts.co.uk/showthread.php?t=12518)
Jon_viola 6th January 2017 04:18 PM
MMI and Nav updates
Hi
Is there a way to check you have the latest possible firmware and if not is it possible to update it?
Ditto mapping.
Jon
MatthewH 6th January 2017 05:46 PM
To check the MMI software version, go to Radio, press "Setup", "Settings" (up-right arrow), "Version". Latest MMI 2G version is 5570.
To check your maps, eject the DVD in the boot and check the label. The reader is behind the removable panel on the left.
Jon_viola 6th January 2017 07:11 PM
Great thanks I'll check tomorrow.
Is it possible to upgrade 2G to 3G?
MatthewH 6th January 2017 08:22 PM
It's been done a couple of times yes, but parts cost alone would be £1k+ (that's with 2nd hand parts!). Lots of modules/wiring need replacing and it's a lot of labour from what I've read. Overall verdict is that it's generally not worth the cost and effort.
Jon_viola 6th January 2017 10:16 PM
Ok thanks for the advice, I'll leave it!
Jon_viola 7th January 2017 04:06 PM
Checked the firmware and its 55.7.0 so I guess thats upto date. Great!
JulianHicks 8th January 2017 07:16 PM
You can check the Navigation version from the MMI. Just select Navigation then click Setup and scroll to 'Version Information'. You'll see a display like this:
Media Version
EUROPA_10600_2413 [1060 is firmware version in NavBox]
Database Version
EHW421/20140806004921 [2014 is Map year - note that this is 2015 DVD]
Regards - Julian
