Switched live on O/S/F fuse box?
Hi. Hope you’re all well. Crazy, surreal times.
Does anyone know if there’s a switched live fuse on the OSF dash fuse box? I’ve wired in a piggy back to USB step down thingy for an aftermarket TPMS unit, hidden away in the knee level cubby hole thing. It has a cut off in case the battery gets below a certain SoC, but I’d like to wire it to a switched live ideally. Especially as the car is getting used less than normal. Thanks in advance. All the best, stay safe. John. |
