-   D3 - Fuel and Exhausts (https://forum.a8parts.co.uk/forumdisplay.php?f=45)
-   -   Exhaust pipe trims (https://forum.a8parts.co.uk/showthread.php?t=7621)
Lyons 13th February 2014 12:56 PM
Exhaust pipe trims
Has anyone ever had the down swept pipes on a 3.0TDi replaced with straight polished tips like those on the 4.2?
I had something similar done many, many moons ago on a Bora I had and it was a simple job for the place that did it- chop of down swept standard exit and weld on replacement tips.
Anyone ever had this done on an A8? Any complications that would make it harder than the above?
M-A8 13th February 2014 04:22 PM
Yeah, on my mates '06 4.2TDi D3, both down tailpipes replaced with straight square ones +++
No complications or ''side effects'' ;)
M-A8 13th February 2014 06:36 PM
1 Attachment(s)
No need to cut ;)
(see attached)
B17NKA 13th February 2014 09:46 PM
Thanks Lyons and M-A8 I asked this same question in the middle of January did not get one reply ?
Mine are tacked on I think ?
Will have a look at the weekend
Looks so much better with straight out pipes
M-A8 13th February 2014 10:27 PM
No problemo +++
Don't forget that not everyone may have so much time on their hands like me to research almost every thread on this forum and then look for answers in ETKA or Elsa :D
I do have to much time ... and I genuinely like helping anyone no matter what, unless something is out of my zone then I will just keep quiet ;)
Lyons 14th February 2014 07:38 AM
Originally Posted by M-A8 (Post 68340)
No need to cut ;)
(see attached)
Excellent news! I just need to find some trims that will bolt on in their place now. It doesnt say what diameter the pipe is at the jubilee clip?
Any idea if the 4.2 is the same set up? If so, are the pipes etc the same diameter? I'm sure that would be too easy.
Lyons 14th February 2014 07:39 AM
What are the differences between 5 and 5A and 4 and 4A?
M-A8 14th February 2014 08:48 AM
From the looks of it diameter on the silencer seems to be same.
No sizes given in ETKA.
You will have to measure it.
Also can't tell what is the difference between 4 and 4A, only from the looking at it one seems to be slightly shorter.
A's are around 40quid more expensive
Lyons 14th February 2014 08:58 AM
Ok cheers.
Is there a part number for the 4.2 trims?
Lyons 14th February 2014 09:58 AM
In fact, looking on autotrader it appears not all 4.2 TDi's came with straight tips.
I might be safer going for 3.0 petrol tips if they were the same diameter.
I'll try and get 1 off at the weekend and have a measure.
