-   -   Picture of A8 D3 toolkit (https://forum.a8parts.co.uk/showthread.php?t=7760)
richardracer 8th March 2014 08:59 PM
Hello,
My toolkit has some items missing. Could I ask someone to take a photograph to help me identify the missing items.
Richardracer
mannyo 9th March 2014 07:06 AM
Mine has items missing as well, I assume it has everything it needs. From memory I have wheel wrench, locking wheel nut key, screwdriver, warning triangle and a tool to remove the wheel centre caps.
Architex_mA8tey 9th March 2014 08:16 AM
You should have an L shaped tool to wind back the EPB as well manny +++
Conquistador 10th March 2014 12:45 PM
I'm sure mine is complete. It has pretty much everything you need in there for quick fixes!
I'll post a pic in a few hours when I'm with my car again +++
Conquistador 11th March 2014 08:17 AM
Hope this helps +++ Looks like I have an empty slot to the right of the top panel :Confused:
http://i59.tinypic.com/2rfsx6v.jpg
http://i61.tinypic.com/2edce85.jpg
http://i62.tinypic.com/b7doxk.jpg
PsYcHe 11th March 2014 11:12 AM
Your empty hole is the same as mine.., I'm guessing that's the little 'wire' tool for removing centre caps.
tonupkid 11th March 2014 11:17 AM
I have the locking wheel nut adapter in that slot
Conquistador 11th March 2014 11:18 AM
Ah yes, could be. Well I have that curly prong thing for pulling the centre caps in the little black case which contains the locking nut
Conquistador 11th March 2014 11:20 AM
What about the hexagonal-shaped hole to the very left on the bottom panel?
PsYcHe 11th March 2014 12:05 PM
Pretty sure bottom left is locking wheel nut
