-   -   Bose Crackle (https://forum.a8parts.co.uk/showthread.php?t=8200)
Sir WIll 17th May 2014 12:55 PM
Bose Crackle
Ladies and Gents,
On the ongoing OCD search for perfection with the D3 I have noticed that there is a "Crackle" coming from the front dash speaker.
Done some work into this and I think it may be the amp but would welcome any feedback if anyone has had any experience with this in the past.
Points to note:
1) CD and Radio both crackle
2) No matter what the music source it crackles
3) This is not cooked or rubbing voice coils on speakers
4) There is no intermittent sounds or breakup
5) Volume and power all OK and no distortion
6) This does not sound like driver distortion
The crackle to me sounds like its not being processed correctly or perhaps an Amp being a little upset hence why I am thinking Bose
PsYcHe 17th May 2014 02:07 PM
Have you tried fiddling the Bose sound settings?
Sir WIll 17th May 2014 02:11 PM
Not touched them, its a valid point as the processing could be the problem.
I shall have a play and see, plus ensure "Crackle" is turned off ;)
Sir WIll 17th May 2014 02:20 PM
mannyo 17th May 2014 07:00 PM
IIRC Ian had some problems with the centre speaker, its dead easy to replace it and that would be where I would start. Replacement speaker should be easy to source from a8parts.
http://forum.a8parts.co.uk/showthread.php?t=6402
Sir WIll 17th May 2014 08:06 PM
Thanks but this is not speaker rattle or distortion here, it's electrical amplification or processing.
I may take out the amp and check the boards.
snapdragon 19th May 2014 06:45 PM
On other makes of car with BOSE, I have read on forums several times this attributed to dry joints within the DSP/amp.
Sir WIll 19th May 2014 06:53 PM
Agreed, that's my thinking on this now also after some Google homework.
May have a look over the bank holiday weekend!
