Retrifit Fingerprint sensor
Hi guys ! I have bought the fingerprint sensor to replace the normal Start Stop button. I have changed the whole thing. Activated the fingerprint feature from the hidden menu. Now i have on the top left the "user" function. If i press the function, comes a error. Do i need to activate something else through the software too ?
Thanks |
I would imagine that you'll have to change the coding on the relevant section with vagcom to tell the car that it has a fingerprint sensor instead of a start button - if you check out rosstech's website they have a simulator that will let you try the menus off the car and show you the coding options +++
